19
NASA has detailed experiments with a new type of parallel array of small electric propellers on the leading edge of the wing technology that they are calling LEAPTech.
The press release notes that the benefits include: "Each motor can be operated independently at different speeds for optimized performance. Key potential benefits of LEAPTech include decreased reliance on fossil fuels, improved aircraft performance and ride quality, and aircraft noise reduction."
A Popular Science article notes that: "When complete, LEAPTech’s planned cruising speed will be 200 miles per hour, with a range of 230 miles on electric power and 460 miles when running as a hybrid. The tremendous and immediate lift generated by this octodecaprop plane and its mere 31-foot wingspan means it should be able to take off from runways as short as 2,000 feet, which is a good 700 feet shorter than the FAA recommends for small passenger aircraft."
Is this related to a spinning wing (Magnus effect) or do the benefits accrue from some other aerodynamic effect? This appears to be a technology that would only benefit very small aircraft and would not be scalable, is this correct?
enter image description here [Photo credit: NASA]
    $\begingroup$ Probably not related to Magnus. This simply allows controlling and accelerating the airflow over the wing for added lift. Should improve lift at take off and landing and allow using lower drag wings. This has actually been tested before using other constructions, the "big deal" here seems to be that small electric propellers are simpler and cheaper than previous solutions were. They worked, but were too complex for practical use. I see no reason why this would not scale. Based on half-remembered things I read somewhere I have forgotten, so take with a grain of salt. $\endgroup$ – Ville Niemi Mar 21 '15 at 20:21
    $\begingroup$ @VilleNiemi: Correct analysis, but for landing the props will not add much flow speed, and the aircraft should still be flyable when power runs out. Therefore, the smaller and less draggy wings look like a pipedream to me. $\endgroup$ – Peter Kämpf Mar 21 '15 at 22:23
    $\begingroup$ @PeterKämpf Yes, now that you mention it, those actually look like high lift wings. (Long, narrow, high camber...) So this would be optimized for slow speed operation and drag reduction is not really a goal. And while this is related to your answer, not this comment, blown flaps was what I was dimly recollecting. Something about the practical issues of doing it... $\endgroup$ – Ville Niemi Mar 22 '15 at 9:56
    $\begingroup$ You might get a slightly better propulsive efficiency by putting the propellers in the wingtip vortex but don´t you think the many propeller gondolas (even with the folded props) will make a gain in effiency unlikely? I´ts highly questionable that there will be laminar flow in the wake of these gondolas (Propeller on or off). Disturbing a low drag wing profile normally results in really nasty behavior. The high lift performance is undoubtable as this is shown in many designs before. $\endgroup$ – user8169 Apr 17 '15 at 7:57
20
The lift augmentation has nothing to do with Magnus lift (or the Coanda effect). It is simply an increase in the dynamic pressure across the entire streamtube of the wing.
At the low takeoff and landing speeds (slightly above a 61 knot stall speed), the induced velocity of the propeller almost doubles the velocity that the wing sees; and the lift is a function of the effective velocity squared. But due to swirl and other effects the wing doesn't experience a 4x increase in lift, but about 2 to 3 times.
The objective of the inboard propellers is not to achieve a high propulsive efficiency, instead we want those inboard props to achieve high induced velocities - think of them as part of the high lift system (which happens to also provide thrust redundancy).
In fact landing is the critical case, and having lower propulsive efficiency (and a poorer spanwise lift distribution because of the swirl effects) is helpful in creating sufficient drag. The inboard props are not active in cruise flight, but simply fold against the nacelle (many motorgliders already do this type of folding on the nose).
By only using the wingtip propeller at cruise, we're able to achieve a ~95% propulsive efficiency (versus 75 to 85% with a typical fuselage nose propeller installation). The reason for this is because we have lower blockage and scrubbing drag, as well as being able to take advantage of the strong wingtip vortex by rotating against it. Since electric motors don't experience a power lapse with altitude (because it's non airbreathing) we have far too much power at altitude anyway so by only using the wingtip motor it doesn't cause much penalty in motor weight (and electric motors achieve ~6x lower weight per horsepower than a reciprocating engine).
In terms of batteries and range, the key is to achieve high efficiency cruise flight and it looks like with current batteries a 200 mile range is achievable. By adding a small <50 hp range extender motor, the aircraft will be able to achieve ~400 mile range. We're currently designing an X-plane that will fly in 2017 to substantiate all these numbers, with the ground test rig (wing and truck) providing an aerodynamic database to validate our analysis.
Please note that I'm the NASA Principal Investigator of the LEAPTech Distributed Electric Propulsion integration approach, and the Convergent Electric Propulsion Technology (CEPT) X-Plane demonstrator. We have a team across NASA Langley and Armstrong, as well as two great small companies, Joby Aviation and ESAero who are retrofitting a Tecnam P2006T with a Distributed Electric Propulsion wing system.
  • $\begingroup$ @Mark -great answer, thank you! If you're connected with Leap (you use the pronoun we), can you indicate so in your answer? $\endgroup$ – RoboKaren Apr 15 '15 at 14:11
    $\begingroup$ Yes, I'm the NASA Principal Investigator of the LEAPTech Distributed Electric Propulsion integration approach, and the Convergent Electric Propulsion Technology (CEPT) X-Plane demonstrator. We have a team across NASA Langley and Armstrong, as well as two great small companies, Joby Aviation and ESAero who are retrofitting a Tecnam P2006T with a Distributed Electric Propulsion wing system. Sorry for the large block of text :) $\endgroup$ – Mark Moore Apr 15 '15 at 14:34
    $\begingroup$ Welcome to Aviation SE! You keep saying "wingtip propeller," but it looks like there are two. Could you clarify that? Also, have you guys found an answer to the unpowered-landing issue (i.e., if there's a total power loss, how can you keep the stall speed low enough)? $\endgroup$ – raptortech97 Apr 17 '15 at 11:06
  • $\begingroup$ @MarkMoore Can you please quantify the penalty in wetted area caused by the motors' nacelles? $\endgroup$ – mezzanaccio Oct 4 '16 at 15:39
  • $\begingroup$ @MarkMoore Peter was skeptical......? He's very experienced, AFAIK. $\endgroup$ – Abdullah Jun 26 '20 at 18:39
11
The main advantage would be similar to that of blown flaps. The flow around the wing will be slightly accelerated, so it operates at a higher effective dynamic pressure. This helps to prevent flow separation and allows to create more lift from the same wing area. This effect should be especially noticeable at low speed, when the relative speed increase in the prop wash is highest. However, for the highest effect the propellers will run at maximum power, so the minimum flight speed will only be possible in a climb and approach and landing will require a significantly higher speed.
Other advantages are:
  • redundancy
  • yaw control by selective power changes
  • Better field of view for pilot and passengers.
However, once your batteries run empty, the plane should still be flyable to make an emergency landing, and for FAR part 23 certification, the minimum speed should not exceed 61 knots, especially not in this case. Therefore, the small wing chord of the pictured airplane looks awfully optimistic to me.
Scaling this will not be hard in principle, but the bigger airplanes become, the harder it is to pack enough battery capacity. Bigger airplanes have higher wing loadings and fly faster, so their specific power needs are higher. For the next decades, electric propulsion will foreseeably not be scalable to transport aircraft.
  • $\begingroup$ Thanks Peter. I added some more information about the estimated cruising speed and range. It notes "hybrid" power which I assume means that that one of the models would also have a piston-engine main propeller. $\endgroup$ – RoboKaren Mar 22 '15 at 0:12
  • $\begingroup$ Peter, do you have any numbers on the actual velocity increase induced by propellers? I always thought the difference is kept small to maintain a high propulsive efficiency. $\endgroup$ – ROIMaison Mar 22 '15 at 9:18
  • $\begingroup$ @ROIMaison: Yes, efficient propellers need small speed increases. Read all about it here. $\endgroup$ – Peter Kämpf Mar 22 '15 at 10:53
    $\begingroup$ @RoboKaren I suspect that hybrid power means that the aircraft will have a generator of some sort on board to supplement the batteries, like the range extender engine in some hybrid cars. $\endgroup$ – squigbobble Jan 22 '16 at 10:47
