25
Let's say that you're on approach to a remote airport to refuel (for arguments sake, Funafuti International Airport, Tuvalu), with 1-2 hours of fuel remaining in your aircraft. Contacting ATC to request permission to land, they tell you that the only runway is closed for an unspecified reason and will not reopen for ~2 hours.
The nearest airport is 295nm away, so you agree to hold, hoping the runway is soon reopened. After waiting a little while, the runway is still not reopened, so you declare an emergency.
Is the airport required to reopen the runway? Does the fact that the nation is not a part of The Chicago Convention change anything?*
Supposing ATC refuse to reopen the runway, is the pilot permitted to land anyway?
Let's presume the aircraft is not certified for ditching.
Searching Google, I found that at least one emergency aircraft has landed on a closed runway.
* 2020 update: in Nov 2017 Tuvalu became ICAO's 192nd member state (icao.int).
  • $\begingroup$ With reference to your example, I'm pretty certain that an airliner can cover 295nm in less than an hour, even when respecting the <= 250 KIAS @ FL <=100 rule (which doesn't apply to emergency situations anyway). $\endgroup$ Jan 26, 2014 at 4:10
  • $\begingroup$ @shortstheory Perhaps an airliner could, but I was referring to small planes. $\endgroup$ Jan 26, 2014 at 4:25
    $\begingroup$ You may have 1-2 hours of fuel on board but other things may require you to land asap. An engine fire for instance... or low oil pressure etc . The airport on the other hand may have been closed for runway work and while they may realise you have no other choice other than clear all man and machine off the runway and pray for you. At the end you are in-charge of getting the airplane down with no loss of life. $\endgroup$
    – Anilv
    Jan 15, 2020 at 1:47
  • $\begingroup$ In an emergency, use of a runway is optional. $\endgroup$
    – Mark
    Jan 16, 2020 at 3:39
5 Answers 5
47
Preflight Planning
Let's say that you're on approach to a remote airport to refuel, with 1-2 hours of fuel remaining in your aircraft. ...
The nearest airport is 3-4 hours away...
First of all, it looks as if the pilot has already broken several regulations in order to end up in this situation. He either didn't file an alternate, or if he did then he didn't carry enough fuel to get to it (and additional reserves as required). If the runway is closed for an extended period of time, there would likely have been a NOTAM stating that the runway would be closed. All of this sounds like poor preflight planning, and probably the 'ole careless and reckless thrown in for good measure.
The Problem
Okay, we need to figure out what the "unspecified reason" is because this can change things dramatically.
turtles at airport
Is it for endangered migrating turtles?
runway construction
Is it for construction?
In any case, he needs to use all available resources. Talk to ATC and explain the situation. Ask them how they can help clear the runway so that we can land. He should tell them that an emergency is imminent without their assistance. They will do everything that they can to help you, including coordinating with people on the ground to get out of the way. Be creative. Did you know that there is no regulation (in the US) requiring you to land on an actual runway? Ask them if you can land on the taxiway. For that matter, land in the grass beside the runway. It would be better than going for a swim or crashing after running out of gas!
Let's presume the airport is surrounded by ocean, and the aircraft is not certified for ditching.
Ummm, who cares if it is certified for ditching? If you are over water, it doesn't matter. If you are over land, it doesn't matter. If you have a choice, pick land (even if it's off-airport).
Well, they wouldn't really do this unless there was a really good reason, mainly meaning that it would be dangerous for the aircraft to land there (like in the second picture above). In this case, we can't really ignore ATC and land anyway until:
Declaring the Emergency
...so you choose to hold, hoping the runway is soon reopened. After waiting a while, the runway is still not reopened, so you declare an emergency.
At least our poor pilot did this right. Rather than blindly continuing to hold, he declared an emergency.
Getting on the Ground
Now we have a lot more latitude and options, and ATC is better able to help us because they can pretty much do whatever it takes to save the aircraft. This can change a "Sorry, there is nothing I can do." into a "Cleared to land any runway or taxiway." all on its own. They may throw in a "Landing at your own risk." if there are still hazards, but that's just to clear them of liability. Even if they still refuse, you can simply advise them of what you will be doing and go ahead and do it. Keep in mind however, that it may be better to scope out an off-airport landing site if the danger is so great that ATC won't allow you to land even under such dire circumstances.
Remember, the pilot is the final authority for safe operation of the aircraft. Get on the ground and sort it out after the fact. (Poor turtles....)
In the end, just do what you can to stay alive, and preferably use the airplane again. There are going to be tons of questions and probably major legal battles. Someone will probably go after the pilot's certificate. On the bright side, he will be around to actually see it happen though.
    $\begingroup$ It's not a requirement to file an alternate unless the forecast weather at the destination is below 2000 ft ceiling and 3 mi visibility +/- 1 hr of the intended time of landing. $\endgroup$
    – RobP
    Apr 10, 2014 at 5:08
  • 7
    $\begingroup$ there are also places where there is no alternate possible for many aircraft types. Say you're on a ferry flight to some Pacific island in a Mooney or C172. You're going to have reserves to circle a while, but the nearest island can be the one you took off from 5-6 hours earlier. $\endgroup$
    – jwenting
    Apr 10, 2014 at 7:28
    $\begingroup$ @RobP Sure. In the US. Under Part 91. I don't think that there are any airports that meet the above conditions in the US though. :-) $\endgroup$
    – Lnafziger
    Apr 30, 2014 at 14:26
    $\begingroup$ "First of all, it looks as if the pilot has already broken several regulations in order to end up in this situation. He either didn't file an alternate, or if he did then he didn't carry enough fuel to get to it (and additional reserves as required). "-- the information given in the question doesn't indicate that there was any requirement to file a flight plan at all. $\endgroup$ Jan 14, 2020 at 13:06
  • $\begingroup$ @quietflyer Well, if his destination is Funafuti, then it is an international flight, and flight plans are indeed required. Even if it wasn't, it's still poor planning as the pilot didn't plan for contingencies. This in itself may break regulations such as the "careless and reckless" one here in the US. At any rate, I stated that it "looks as if" he broke several regulations, and didn't say that they did for sure. I try to provide info that people can learn from, and hopefully allow them to think about situations like this in a different way so that they never happen in the first place! $\endgroup$
    – Lnafziger
    Jan 23, 2020 at 6:14
21
There is plenty of room between the request to land, and declaring an emergency to sort things out. After all, if the runway is closed, the tower isn't too busy. It would probably go something like this:
ATIS: Runway 12 is closed.
Pilot: Foobar approach, N12345.
Tower: N12345 go ahead.
Pilot: Foobar approach, we are having some technical difficulties, please advise, what is the nature of the closure of runway 12? N12345.
Tower: N12345 Threshold is being painted.
Pilot: Yeah, approach, we may have a faulty gauge, we are showing a faster fuel burn than expected, we'd like to get on the ground and take a closer look, we can land a little long.
Tower: Roger N12345, report runway in sight.
Pilot: Runway 12 in sight, N12345.
Tower: N12345 You are cleared to land runway 12.
The pilot is then obligated to buy a box of donuts for the tower, and thank the tower and the ground crew. He may get a warning, but equipment failures do happen, and they aren't always an emergency.
Everybody makes mistakes. Aviation is as much an art as a science. So while the rules are important, they are only religion to the lawyers, and only then after something goes horribly wrong. To the people who actually work in aviation, it is about safety, and professionalism, and being good at what you do. And that requires a certain amount of flexibility.
If you already declared an emergency all bets are off, and you must do whatever is required to save the vehicle. There can be no talk about being 'permitted' or even 'cleared' to land if an emergency has been declared.
ICAO Annex 2 2.3.1 Responsibility of pilot-in-command
The pilot-in-command of an aircraft shall, whether manipulating the controls or not, be responsible for the operation of the aircraft in accordance with the rules of the air, except that the pilot-in-command may depart from these rules in circumstances that render such departure absolutely necessary in the interests of safety.
Faced with bad weather, some icing, and an aircraft with a collapsed gear on the runway, I landed on the taxiway.
The matter was complicated in that ATC was unaware of the runway closure. This was at night, in the winter, and the airport owner / manager fired up his equipment to light up the incident area, and did not file a NOTAM until after I was on the ground. I found out when I was five miles out on the approach and made a call on the CTAF. I asked if the taxiway was plowed and free of equipment and personnel and was told it was, and announced my intentions. The airport manager acknowledged on the CTAF.
The FAA FSDO Inspector arrived as I did. Before we left, he came over and talked with me, and I mentioned that ATC was unaware of the incident. Nothing was said adverse to landing on the taxiway.
From my perspective, that option had less risk then doing a missed, and getting back up into the ice. With a light load already on the plane, it would have been hard to get above the icing layer.
Well, the runway closure would be NOTAM'd. I have no idea what the deal is in other countries, but in the US, per 14 CFR Part 91.3 "any pilot may deviate from any rule in this part to the extent of the emergency" or something similar. I would guess it's the same deal in other places. And if ATC is aware of it OR it is for the safety of those on board the aircraft, the FAA will not mind.
