Where can I purchase the air diffuser located in the overhead compartment of each passenger aircraft seat? I need them for a non aviation application. Thanks
$\begingroup$ Seems easy enough to mock-up with a 3D printer. $\endgroup$– RoboKarenMar 17, 2015 at 5:26
1 Answer
The technical name appears to be "Eyeball Air Vent". A Google search turned up a number of hits.
Here's an aluminum product from one manufacturer:
Here's a plastic model more in line with what you'd see on an airliner, from a different seller:
