I'm told that, depending on the heading of your aircraft, you have to fly at particular altitudes. Which, of course, makes sense because having planes flying in opposite directions at the same altitude is just asking for a mid-air collision.
My question is this though: What about when you are changing your heading? Pretend, for example, that for some reason you need to go the exact opposite direction (so, we were going due west, but now we are going due east, for example.) I know you have to gain or lose 1000ft. But do you change altitude after the heading change, before, or during?
So: What's the proper procedure for changing altitude when you change headings?
Bonus points:
  • Is this made more complicated if you are flying Visual Flight Rules instead of Instrument Flight Rules?
  • Are all these rules thrown out the window in Class B and C controlled airspace?
    $\begingroup$ Oh come on! Now that I have typed up a lengthy answer, you change the tag to FAA-Regulations? :P $\endgroup$ Mar 12, 2015 at 17:51
  • $\begingroup$ @SentryRaven I thought yours applied to FAA?! It's why I changed it! $\endgroup$
    – Jay Carr
    Mar 12, 2015 at 17:52
    $\begingroup$ Well, my answer is general. It should apply to FAA regulations as well, but I didn't quote any AIP or FAR/CFR quotes... maybe others will want to improve my answer... plus, I wouldnt even know which FAA regulations to quote, since I am an ICAO-boy... $\endgroup$ Mar 12, 2015 at 17:53
    $\begingroup$ @SentryRaven You never know around here, that's for sure. Thanks for the answer you've posted thus far though. $\endgroup$
    – Jay Carr
    Mar 12, 2015 at 17:54
    $\begingroup$ Well, this really should be tagged with somebody's regulations, since it likely isn't exactly the same world wide. Heck, even "Class B and C controlled airspace" isn't the same world wide.... $\endgroup$
    – Lnafziger
    Mar 13, 2015 at 3:38
11
TL;DR:
Do you change altitude after the heading change, before, or during?
When flying under Air Traffic Control, you are expected to execute instructions after you receive them, following the motto Aviate, Navigate, Communicate. When receiving a turn and climb instruction at the same time, you are expected to start both, e.g.
 DELME, turn left heading 220, descend FL80
You do not change altitude or flight level on your own when flying IFR. When flying VFR, you should adhere to the semi-circular rules when changing your direction and end up in one of the semi-circular areas. On turn techniques that allow direction change and altitude change at the same time, see Tyler's answer.
Yes and No, because remember: You do not change altitude or flight level without being cleared or instructed to do so when flying IFR. Whether having to choose the correct altitude or flight level when flying VFR is more difficult than having ATC select one for you, is debatable.
Additional Information:
The rule you are talking about is the semi-circular flight level rules, which depending on the country, can either be applied West to East or North to South. Let's assume the example you have already used and differentiate between westbound and eastbound flights.
(Image Source: TU Wien)
The above picture shows that aircraft on a eastbound general track between 000° and 179° are bound to odd flight levels, such as FL210, FL230, FL250, etc.
Opposite traffic on a general track between 180° and 359° is bound to even flightlevels, such as FL220, FL240, FL260, etc.
This flight level you are bound to use is also the flight level you request in your flightplan, called the Requested Flight Level or RFL.
Imagine you have a flight going westbound and you have requested FL280 as your cruise level. You would maintain this flight level until you are cleared to descend by ATC. Even if a portion of the descent or arrival route leads in the opposite direction of your orignal track, it will be ATC who is responsible to assign the correct desend flight level, but these do not have to be necessarily following the semi-ciruclar flight level rules.
There is one scenarion where a pilot may want to initiate a flight level change due to changing jurisdiction and use of the semi-circular flight level rules, which is when crossing borders between countries that use west-east and north-south rules. If are on a westbound flight (approx track: 200° that requires even flightlevels, such as FL280 and cross the FIR border into a country with north-south rules that require an odd flight level, you would have a step climb or descent in your flightplan to accomodate this, e.g.:
[...] FIXXA UZ123 CROSS/N0265F290 UZ123 FIXXB [...]
It would still be ATC who clears you to climb to FL290 at that fix, but this way your flightplan is in accordance to local semi-circular flight level rules. Remember that when flying IFR, you never change the altitude or flightlevel unless you have been instructed or cleared to do so.
The same semi-circular flight level rules apply to VFR, just with the added 500ft to stay clear of the IFR flight levels. In most cases however, VFR does not entirely follow these rules, as the are VFR and their separation is based on visual identification and the see-and-avoid principle.
I am not familiar with airspace class B procedures, but in class C airspace, you require permissions to enter the airspace and will thus be assigned restrictions, which can be either a single altitude or flight level, an upper or lower restriction or a level or altitude band. If you are assigned either of the two latter options, you could apply the semi-circular flight level rules.
See below on an overview how other countries handle these semi-circular rules.
(Image Source: Delta Virtual Airlines - Not for real navigational use)
See also these related questions:
What is the difference between “flight level” and “altitude”?
What differences are there in Flight Level rules, internationally?
    $\begingroup$ Fascinating but it does not answer the question. $\endgroup$ Mar 12, 2015 at 17:56
  • $\begingroup$ @TylerDurden If the question were 'should I first eat the top or bottom part of a banana peel', then 'you should not eat a banana peel' is a perfectly acceptable answer! But with Pondlife's second paragraph, the OP's question is fully answered. $\endgroup$
    – Sanchises
    Mar 13, 2015 at 11:35
  • $\begingroup$ @TylerDurden: I see what you mean. I have restructured my answer to better fit the question asked, I thought at firs the was asking about how to chose the proper altitude/flight level and not how to climb and change direction at the same. I have left the part about semi-circular flight level in though as additional info. Does this look better now? $\endgroup$ Mar 13, 2015 at 13:24
  • $\begingroup$ @SentryRaven His essential question is, to quote from the post: "...do you change altitude after the heading change, before, or during?" Which I already answered: usually you turn before you change altitude because you turn faster than you can change altitude, although sometimes you can do a climbing turn and do both maneuvers simultaneously (see my answer). $\endgroup$ Mar 13, 2015 at 13:27
  • $\begingroup$ @TylerDurden I got that, hence why I updated my answer. It should fit now, the upper part. $\endgroup$ Mar 13, 2015 at 13:28
This answer is somewhat US-based so details may vary but I think the principles are the same everywhere.
Under VFR there's no specific procedure because you're maneuvering at your own discretion and maintaining your own separation from other aircraft visually. Even if there was a specific procedure - let's say it's climb first, then turn - what would you do if that procedure took you straight through a cloud? Or into airspace that requires a clearance? There are far too many possible variables, so it's always left up to the pilot to determine the safest path of flight under VFR.
Under IFR you usually only make heading and altitude changes as instructed by ATC, meaning the issue doesn't arise, with (at least) two exceptions. First, you may be operating VFR-on-top but in that case you're effectively operating VFR and the previous remarks apply. Second, you may be on a cruise or block clearance and then you can climb and descend as you want anyway (with some restrictions).
As for class B and C airspace, in theory the cruising altitude rules apply everywhere above 3000'agl (in the US) but in those airspaces you're required to be in contact with ATC and their instructions will take precedence anyway.
In general, you can turn faster than you can change altitude, so normally you would first make the turn and then focus on climbing or descending to the target altitude.
Note that you can perform a climbing turn or descending turn, but usually you still have to continue adjusting altitude after the turn is complete. Sometimes you can make a climbing turn which ends up exactly 500 feet higher, so you are right on target. In that case both objectives are achieved simultaneously.
The answer is the same for both IFR and VFR and the type of airspace. When a controller gives an aircraft a new vector they do not tell the pilot how to execute the turn (other than sometimes specifying the direction left or right). For example, the controller might say:
November tree two five one zero, turn left heading one five zero / fly heading one five zero, climb and maintain five thousand five hundred feet
  • $\begingroup$ The only phraseology where ATC does not provide a turn direction is Fly Heading XXX. Turn instructions require a direction of turn, e.g. Turn left/right heading XXX or Turn left/right by XX degrees. $\endgroup$ Mar 13, 2015 at 13:12
  • $\begingroup$ @SentryRaven I made a more exact phraseology quote, including an optional turn instruction. $\endgroup$ Mar 13, 2015 at 13:19
