If I want to launch high power rockets NOT at a NAR or TRA sanctioned launch, assuming I am properly certified, what do I need to do? I looked in the FAR|AIM, but I couldn't find anything on rockets, but I think the rocketry section has been omitted from the PPT FAR|AIM.
The FAR section that you are looking for is available on the ecfr website:
PART 101—MOORED BALLOONS, KITES, AMATEUR ROCKETS AND UNMANNED FREE BALLOONS
More specifically, it is Subpart C— Amateur Rockets
The main regulations that apply are (see the above link for the full text of the regulations):
§101.23 General operating limitations.
(a) You must operate an amateur rocket in such a manner that it:
(1) Is launched on a suborbital trajectory;
(2) When launched, must not cross into the territory of a foreign country unless an agreement is in place between the United States and the country of concern;
(3) Is unmanned; and
(4) Does not create a hazard to persons, property, or other aircraft.
(b) The FAA may specify additional operating limitations necessary to ensure that air traffic is not adversely affected, and public safety is not jeopardized.
§101.25 Operating limitations for Class 2-High Power Rockets and Class 3-Advanced High Power Rockets.
When operating Class 2-High Power Rockets or Class 3-Advanced High Power Rockets, you must comply with the General Operating Limitations of §101.23. In addition, you must not operate Class 2-High Power Rockets or Class 3-Advanced High Power Rockets—
(a) At any altitude where clouds or obscuring phenomena of more than five-tenths coverage prevails;
(b) At any altitude where the horizontal visibility is less than five miles;
(c) Into any cloud;
(d) Between sunset and sunrise without prior authorization from the FAA;
(e) Within 9.26 kilometers (5 nautical miles) of any airport boundary without prior authorization from the FAA;
(f) In controlled airspace without prior authorization from the FAA;
(g) Unless you observe the greater of the following separation distances from any person or property that is not associated with the operations:
(1) Not less than one-quarter the maximum expected altitude;
(2) 457 meters (1,500 ft.);
(h) Unless a person at least eighteen years old is present, is charged with ensuring the safety of the operation, and has final approval authority for initiating high-power rocket flight; and
(i) Unless reasonable precautions are provided to report and control a fire caused by rocket activities.
§101.27 ATC notification for all launches.
No person may operate an unmanned rocket other than a Class 1—Model Rocket unless that person gives the following information to the FAA ATC facility nearest to the place of intended operation no less than 24 hours before and no more than three days before beginning the operation:
§101.29 Information requirements..
