13
And why do military fighters/bomber require so many maintenance hours compared to commercial airlines, which seems like just kicking the tires? What do they actually do?
How does maintenance differ for fighters vs. bombers?
As many of the comments and answers have illuminated, "different missions drive different design priorities." Examples of differences in specific maintenance activities would be greatly appreciated.
    $\begingroup$ Based on the inspection/maintenance schedule Johnny listed in this answer, I wouldn't say commercial airlines just 'kick the tires'. $\endgroup$
    – FreeMan
    Mar 6, 2015 at 16:41
    $\begingroup$ Standard military adage, "If its not leaking, its empty". I wouldn't assume that military aircraft have superior reliability and maintenance because they receive more frequent attention. This is likely just a side effect of flying in a more stressful flight regime than typical civilian aircraft. Constantly bending the jet takes a toll on the aircraft. $\endgroup$ Mar 6, 2015 at 18:09
  • 9
    $\begingroup$ Military aircraft are high performance machines that operate far beyond the performance envelope of commercial passenger aircraft. As a civilian analogy, F1 race car gets its engine rebuilt every 500 miles or so, while a commercial bus might go 15,000 miles between oil changes (or longer if they have an oil analysis program) and with proper maintenance, can stay on the road for 500,000 miles or more without needing a major engine overhaul. $\endgroup$
    – Johnny
    Mar 6, 2015 at 18:24
    $\begingroup$ @Johnny So do they perform the same maintenance activities, just on an accelerated schedule? $\endgroup$ Mar 6, 2015 at 18:27
    $\begingroup$ Upvoted @SHAF "I wouldn't assume military...have superior reliability." Spot on. My experience Air Natl. Guard and active duty. Required/routine mx was the same. Active duty planes flew more hours but broke more often far beyond the rate of hours. Natl Guard folks tend to be older and vastly more experienced and it showed dramatically in mx. On active duty I shut down 6 engines in about 1st 100 hrs, 3 were on consecutive flights. But in the Guard maybe 3 total in 1,200 hrs - and at least 10 yr older planes. $\endgroup$
    – radarbob
    Mar 13, 2015 at 4:11
I think a few things need to be examined here:
1) The type of flying. A commercial aircraft is closer to a military C-17 than a B-52 or F-16 in how it is used. It has several stops throughout the day for loading and unloading. The maintenance in between stops does not need to be very extensive - because it has just landed, presumably working fine, the things that need to be checked primarily involve what has the most chance of decaying during a flight (tires, oil, general wear and tear, etc). Fighters/bombers don't generally fly several legs in a day. Fighters might double/triple turn, and in between each of these flights the maintenance inspection is a much lower requirement than between each day of flying.
2) Component Requirements. Supersonic jet engines need maintenance more often than high bypass commercial engines. They are stressed much more, and work on a much tighter margin of error, thus fighter/bomber aircraft need maintenance more often.
3) Age. Military fighter/bomber aircraft are on average much older than the average commercial aircraft. B-52's are from the 50's, and B-1's are from the 80's (along with most of the fighter fleet). Older aircraft require more maintenance, and there is no avoiding it.
Between fighters and bombers, they each have different flying styles. Fighter engines work a lot harder than bomber engines (except the B-1, which essentially has the same engine as an F-16), and thus require maintenance more often. Bombers are much larger, and have more systems that can break.
Hope this helps.
Update: Incorporating a suggestion from the comments below, it is probably useful to specifically mention a few more specific maintenance items unique to combat aircraft
1) Ejection Seats: Most military combat aircraft carry ejection seats, which have a very specific maintenance routine. This may include repacking the associated parachute, and checking to ensure that all components are functional/in good repair.
2) Weapons: The obvious difference between fighters/bombers and commercial airliners is that they carry weapons. This means that there is a software package that needs to be maintained (that controls the weapons), the aircraft hardware needs to be maintained (ie bomb bays, missile racks, hard points, etc), and the weapon itself requires building/deconstruction.
3) Flight Computer: Combat aircraft often have tactically specific functions in their flight computer that a commercial airliner would not. There are routines to help calculate bomb trajectory, to link with other combat aircraft and many other military specific tasks that a commercial airliner would not need.
I would agree with an earlier statement stating that performance has a slightly higher emphasis than reliability in military aircraft than in commercial aircraft. It's easy to see how the requirement to carry bombs/missiles increases aircraft gross weight, which lowers fuel efficiency. Every internal bomb bay could potentially be a fuel tank extending range. Hard points, even when bombs aren't installed, cause drag lowering performance. In the end, designers have to determine which capability is more important - endurance, payload, power, etc. You may want to install a triply redundant INS in a fighter aircraft, but you're adding weight that decreases performance, and taking space which could be devoted to other avionics (like radar).
    $\begingroup$ Do you have any examples of specific maintenance activities unique to fighters/bombers (vs airliners)? $\endgroup$ Mar 13, 2015 at 14:06
    $\begingroup$ The biggest thing to point out is that fighters/bombers have weapons, and weapons systems which need maintenance. So the hard points, weapons delivery systems, etc all need maintenance while commercial aircraft do not. Fighter/bombers also have ejection seats, where commercial aircraft do not. These seats require regular maintenance (parachute repacks, inspections, etc). $\endgroup$
    – tmptplayer
    Mar 14, 2015 at 20:43
  • $\begingroup$ Interesting. How do you actually maintain a weapon? What something specific you actually do? $\endgroup$ Mar 14, 2015 at 21:10
  • $\begingroup$ @tmptplayer That is a good point to add to your answer. You might also mention the design tradeoffs involved with the different requirements. $\endgroup$
    – fooot
    Mar 16, 2015 at 19:01
    $\begingroup$ @HephaestusAetnaean When you eject a bomb, an electric charge detonates a small explosive cartridge (roughly the size of a shotgun shell) which actually moves the mechanism holding the bomb. Naturally, anything which has to endure explosive charges (even small ones) will require inspection, cleaning and, occasionally, replacement. Additionally, modern aircraft guns are usually multi-barrel (Gatling guns). Any gun is going to have lots of small, intricate parts for chambering, firing and ejecting the rounds, plus moving rounds from the magazine (chain mechanisms, not WW II-era belts). $\endgroup$
    – Meower68
    Mar 17, 2015 at 19:20
+50
Military aircraft are designed to maximize performance, while commercial airliners are designed to maximize reliability.
That's not to say that reliability is unimportant for the military aircraft or that performance is unimportant for the airliners, but when almost everything is done and the last tradeoff is considered, the military jet can accept a little more maintenance in return for a little better performance, while the airliner will probably sell better with better reliability & the ability to go longer between maintenance down-time, even at the cost of the last 0.2% better performance/weight/economy/etc.
The assumption for military aircraft, fighters & bombers in particular, is that they'll finish the day back at their base, and they CAN be worked on for several hours before they're launched again. (Generality here -- yes higher tempo ops are possible, but it's the exception not the rule.) Airliners, on the other hand, typically will fly for days between maintenance checks (beyond adding oil, checking tire pressure, and maybe swapping a particular broke part) -- and that's what's desirable because that's how the airplane makes the most money. So that ability to go for so long between maintenance checks is built in because that's what the customer (the airlines) demands.
Could you get more performance out of an airliner if you were willing to accept more maintenance costs? Sure, but it wouldn't be worth it to the airlines. At the extreme, the Concorde, for all its cool factor, was an economic disaster, even though its performance was superlative.
The military aircraft have redundant systems in order to survive -- limp back to base. Commercial aircraft have redundant systems in order to be able to be dispatched again -- stay in service until repairs can be performed. (Obviously, not everything can be deferred; some things ground the airplane & have to be fixed before it flies again... but a LOT of stuff in the airliner can be deferred & you still have redundant capability to land safety even if another system goes down.) As an example, the F-16 was (may still be) single-INS + single-FMS. The system works or you don't launch. Modern airliners have two or three INS's and FMC's -- dispatch with one INS inop is possible (probably day VMC only), and dispatch with one FMC inop has minimal limitations (no long overwater legs, essentially).
Different missions drive different design priorities, and that in turn shows up as differing levels of maintenance that's required.
  • $\begingroup$ Yes, I'm familiar with the different design priorities. Hmm, I think i should reword to question to emphasis the specific activities. Thanks for the INS/FMS example. And thanks for answering! $\endgroup$ Mar 18, 2015 at 3:36
    $\begingroup$ fwiw, us army readiness goals are 75% fmc (fully mission capable), 80% mc (one or more design capabilities/requirements cannot be met), with no more than 10% downtime due to parts not on hand, no more than 10% downtime due to maintenance, and no more than 5% time spent "partially mission capable". source: ar 700-138 $\endgroup$
    – Erich
    Mar 18, 2015 at 4:24
