What will be the reliability of the VOR indication inside the cockpit if one of the two outside antenna is broken ?
Can we trust it to make a VOR approach?
What will be the consequences assuming that we are in a general aviation aircraft like cessna 150 / 172 / 182 .
Picture of antenna:
Picture of antenna
(Image Source: http://www.simmer.fr/)
5 Answers 5
13
No, it should not be used.
Twin antennae, as you have shown, are balanced and fed into a balun (BALanced to UNbalanced) to feed the single transmission line to the receiver. Together, they provide the correct impedance for the aerial system. With an antenna broken, it is likely that the impedance of the circuit is wrong and therefore, the input to the receiver is, at best, suspect.
[GUESSWORK]
It's impossible to predict the indicated behaviour without knowing precise details of the aerial fit but a reasonable guess would be that the standing wave ratio in the feed will be altered and therefore, a phase error will be introduced. The magnitude of the error will vary in proportion to the sine of the actual phase angle so my guess would be that the bearing will be accurate when due South or North of the VOR then increasingly inaccurate as you move round with an maximum error at 90 or 270.
[EDIT]
Early in the morning when I first wrote this but I think I am wrong about being accurate due North or due South. It will be accurate somewhere on the compass and at 180 degrees opposite to that, with increasing inaccuracy as you move towards 90 degrees away from that somewhere. Only calibration would tell you where the somewhere is.
    $\begingroup$ Losing one pole of the VOR antenna can indeed cause a phase offset in the signal - at the very least it mucks with the dipole pattern of the antenna. You'd be amazed how well a VOR receiver can work when both of the cats-whisker antennas are snapped off though (this happened to the plane I did my training in as a result of "a freak plane-washing accident" -- the receiver actually worked BETTER that way). Of course being that the antenna is damaged that still leaves you in a situation where you shouldn't use it. $\endgroup$
    – voretaq7
    Feb 27, 2015 at 7:50
The literal answer is, who knows? The only way to find out for sure would be to calibrate the VOR and observe the deviation - if any - from the expected readings. The instrument manufacturer might have some general guidance, but no one can predict the results of physical damage accurately.
But having said that, it doesn't really matter anyway: you shouldn't be doing anything that requires a VOR if you know that the equipment is broken. Even if it still seems to be accurate despite the missing antenna, what happens if you lose the other antenna? Or some broken wiring starts causing intermittent false readings?
And although this is getting away from the exact question that you asked, there are regulations to consider. You didn't mention a specific jurisdiction, but let's assume US/FAA for now, I'm guessing the general rules are very similar in most places. If you're VFR then you don't need a functioning VOR anyway: by definition, you will never be relying on it for anything because you're navigating visually. It might be helpful to have a VOR in VFR, but it isn't required. (14 CFR 121.349 does allow for VFR flights on routes where you can't use pilotage, but it also requires two independent navigation instruments.)
On the other hand, if you're IFR then it would probably be illegal for you to rely on a VOR that you know is damaged. 14 CFR 91.205 requires "navigation equipment suitable for the route to be flown", and I think it would be difficult to convince the FAA that a VOR with a broken antenna is suitable for navigation.
But the most basic point of all is that relying on broken equipment is just dangerous, especially for an instrument approach where you're relying on the accuracy of the instruments to prevent you from colliding with the ground or an obstacle. In my opinion, taking that chance would show very poor decision-making and general airmanship.
The only effect of a broken VOR antenna is that the polar pattern of the antenna will be altered, and its efficiency as an antenna decreased because it will be mismatched to the feed line. This means that you may only pick up the VOR when the "good" antenna element is closest to the beacon, and its lower efficiency will mean that the range from the beacon you get a signal will be decreased.
The navigation information is all carried in the 30 Herz modulation on the main carrier and the FM subcarrier: nothing in the VOR receiver ANTENNA can affect the phase relationships of the 30 Herz.
If the warning flag is not showing, there is adequate signal and the VOR bearing will be accurate.
Not good practice to leave an antenna broken in this way, but it is not an issue regarding safety as long as you've got enough signal (i.e. no warning flag).
Exactly the same applies if you're receiving an ILS localizer - the information is in the 90 and 150 Herz modulation in this case. As long as the warning flag isn't showing the information WILL BE ACCURATE.
  • $\begingroup$ +1 on the relevant thing. The antenna damage only affects useful range. As long as the warning flag is not showing, the instrument will be accurate. $\endgroup$
    – Wirewrap
    Dec 27, 2015 at 22:36
  • $\begingroup$ "The antenna damage only affects useful range", yes that seems correct to me too. $\endgroup$
    – mins
    Sep 28, 2020 at 9:38
VOR's direction doesn't come from the aircraft seeing where it comes from.
VOR works by a pulsing omni-directional beacon and a sweeping narrow beacon. The pulse happens each time the sweep is north. Then the heading from the compass is used to see where the beacon is relative to the airplane.
(Image Source: Wikipedia - Author: Orion 8)
Does this mean that you can use it for navigation with a missing antenna?
Not unless the system was designed to compensate for a missing antenna.
    $\begingroup$ This doesn't seem like a complete answer to the question. You show that a single antenna is able to receive a VOR signal, but is it safe to use? Will it be accurate enough? $\endgroup$ Feb 27, 2015 at 2:36
    $\begingroup$ -1 I agree with raptortech97, you can't screw with the engineering, don't allow a little knowledge about how something works to temp you into thinking you know better. I can't count the number of Flight Safety courses I've attended where student try to out-smart the design of the aircraft. Go by the book; if something is broke, fix it! $\endgroup$
    – Steve H
    Feb 27, 2015 at 3:23
  • $\begingroup$ @raptortech97 I amended the answer to add that. $\endgroup$ Feb 27, 2015 at 8:39
    $\begingroup$ I don't think this answers the question, but it is the best description I've seen on how the VOR system allows a plane to figure out where it the world it is. If I were to post a "How does VOR work?" question, this would likely be my accepted answer! $\endgroup$
    – FreeMan
    Feb 27, 2015 at 14:53
    $\begingroup$ That's not a very accurate description of how a VOR works. This has a better descriptionHow does TACAN Work? $\endgroup$
    – Gerry
    Jan 25, 2019 at 12:51
-4
Short answer: no.
In general, if a piece of equipment has an operability issue, it should not be used for navigation.
That said, if you test it and the test indicates it is functioning reasonably, it may be ok to use it on SHORT TERM BASIS. So, for example, if I were taking off from Manchester I would fly up to the Cordcord VORTAC and see if I were getting reliable readings. If so, I would probably feel ok using it on a VFR approach.
In any case, the antenna should be fixed before using the instrument long term. To use the receiver with a damaged antenna once or twice is excusable, but not for an extended time.
Note: By "reliable" readings I mean you are receiving a signal at different attitudes, or at least in the attitude you need for navigational purposes. The effect of a broken antenna will be to reduce your gain or possibly introduce a blind spot into your reception area. Note that these effects are ALWAYS present anyway. For example, in mountainous terrrain or if the VOR is straight ahead you could have blind spots in the VOR even with a perfect antenna. So, a broken antenna basically just makes standard reception problems you already have, worse.
  • 7
    $\begingroup$ Using it as a source of navigation at all would be irresponsible period. There are two antenna for a reason, otherwise the manufacturer wouldn't have them both there. $\endgroup$
    – Lnafziger
    Feb 27, 2015 at 3:01
  • $\begingroup$ @Lnafziger Its easy to sit back in your chair and lecture somebody about how their aircraft should be perfect and you should never use so much as a cracked anything, but in the real world sometimes you need to use an imperfect piece of equipment. What if the guy is at a remote airfield? Tell him to use dead reckoning? Is that your plan? A VOR with one antenna is a lot better than dead reckoning I can tell you that. Sometimes you have to fly with a lot more busted than one antenna. $\endgroup$ Feb 27, 2015 at 10:45
    $\begingroup$ @TylerDurden The consequences of using a malfunctioning VOR can be pretty severe (like "Wandering into restricted airspace because your bearing was wrong" severe) if you're using it for primary navigation, and as Simon noted it may work fine on one bearing but be off on others. In your hypothetical situation I would tell the stranded pilot to wait for a good VFR day, pull out their chart, and rely on good old-fashioned pilotage to get them home (or more likely in this 21st century of ours point at their smartphone and remind them they have a GPS in their pocket they can use to help them out). $\endgroup$
    – voretaq7
    Feb 27, 2015 at 18:05
    $\begingroup$ @voretaq7 A damaged antenna is not the same thing as a "malfunctioning" VOR. The effect of a damaged antenna would be to reduce its gain. The typical bad outcome would be that you might get no signal. Simon's idea that it would somehow affect the accuracy of the signal is completely wrong. The phase shift on VOR is to the modulation frequency, not the carrier frequency. Basically he has no idea what he is talking about. $\endgroup$ Feb 27, 2015 at 18:27
  • $\begingroup$ @TylerDurden I think 10 years as an avionics engineer gives me a reasonable background to comment, it addition to having done troubleshooting on such problems using some quite advanced signal analysis tools. But since my professional knowledge is incorrect, I would welcome knowing what your credentials are and exactly why the problem of the standing wave ratio being altered is incorrect. Were there one antenna, I might agree but given that one of the two in a balanced system is damaged, the change in gain is a secondary concern. $\endgroup$
    – Simon
    Feb 28, 2015 at 9:16
