49
As shown in the images below, what are these wavy lines on the canopy of the aircraft? Do these lines have any utility?
These are mostly captured in videos of cockpit views of carrier-based aircraft.
  • 19
    $\begingroup$ That top picture is the view from a T45. The DET cord is designed to rain molten shards of glass down on the pilot, preferably into the neck and eyes (always use your visor!). I suppose it also has the secondary benefit of weakening the canopy for escape during the ejection sequence, but we were always under the impression that if you pulled the handle you were gonna get burned. $\endgroup$ Feb 22, 2015 at 17:29
  • $\begingroup$ What type of jets are those in the bottom picture? $\endgroup$
    – dalearn
    Dec 15, 2017 at 21:47
  • $\begingroup$ @dalearn Looks like a BAE Hawk. $\endgroup$
    – Colin
    Feb 14, 2018 at 15:49
  • $\begingroup$ The one on the right is a BAe Hawk but the one on the left is the Dassault Alpha Jet operated by QinetiQ. $\endgroup$
    – Adrian
    Feb 15, 2018 at 8:49
51
It is an explosive cord which helps to crack the canopy (pdf!) before the ejection seat has to do this all by itself. When ejection is commanded, the harness is tightened and the canopy is shattered, and only then the real ejection starts. Earlier designs would blow the full canopy off, but this takes longer than shattering it, especially when the canopy is large.
Some seats have their own canopy breakers, but thick, tough canopies which are needed for flying at high dynamic pressure and for surviving bird strikes would slow the seat down too much. The F-16 canopy is 12mm thick in the area above the pilot.
They are used widely for both land- and carrier-based aircraft, and modern designs try to make them less obvious. The F-35 canopy uses just one line down the middle.
    $\begingroup$ Are these chords specific to carrier-based a/cs or I just happened to view the few right ones? i.e. does this class of a/cs need this more than others? $\endgroup$
    – Raj
    Feb 20, 2015 at 20:35
    $\begingroup$ Is that a Chord, Chord, Cord or Cord? :) $\endgroup$
    – FreeMan
    Feb 20, 2015 at 20:46
    $\begingroup$ @FreeMan: Thanks, fixed it. Or is it a rope? $\endgroup$ Feb 20, 2015 at 21:01
    $\begingroup$ FYI, it's called MDC, Miniature Detonating Cord. $\endgroup$
    – Simon
    Feb 20, 2015 at 21:14
    $\begingroup$ @Simon … or FLSC - Flexible Linear Shaped Charge. $\endgroup$ Feb 20, 2015 at 21:16
31
For completeness, there are also several other mechanisms to make sure the pilot does not "punch through" the canopy, which would likely be fatal.
As well as the detonating cord, many canopies unlock at the front when the ejection handle is pulled. The airflow gets under the lip of the canopy and tears it off the aircraft. The hinges at the back are designed to break in this scenario. Other canopies have explosive charges which detach the canopy. The Harrier, amongst other examples, might require the pilot to eject at zero or low forward airspeed so utilises detonating cords to make sure that the canopy is shattered.
Some seats also have a rail which extends upwards at the start of the sequence, the top of the rail being designed to shatter the canopy. The seat then travels up the rail. The seat itself might also have "canopy buster" spikes fitted at the top such that if the canopy does not detach or shatter, the seat will break through the canopy and the pilot will not be too shredded by the broken plexi-glass.
The ejection sequence is carefully controlled with mechanical timers which, although everything happens fast, make sure that the pilot does not hit the canopy and is ejected clear of the aircraft. It's very complex, with a sequence of pins being withdrawn, timers started, rockets fired and so on but at least one manufacturer, Martin Baker, has a proud record of never having had a seat failure other than for user or maintenance error.
  • $\begingroup$ In some egress systems the timers are pyro delays rather than mechanical -- less to go wrong. $\endgroup$
    – stevegt
    Jun 18, 2017 at 4:55
