Can X-Plane be used as an actual Flight and Navigation Procedures Trainer (FNPT) level 1 flight simulator with Out The Window (OTW) visuals, separate Instructor Operation Station (IOS) and replica hardware?
1$\begingroup$ there's the professional option when buying Xplane for setting up commercial simulator. Don't know how far it goes, or how far people have gone with it though. $\endgroup$– falstroFeb 18, 2015 at 9:24
$\begingroup$ Can you possibly clean up your question and write out what OTW and IOS stand for? Not everyone will be familiar with these terms. More information might be required for users to answer your question, too. $\endgroup$– SentryRavenFeb 18, 2015 at 10:05
1$\begingroup$ related: aviation.stackexchange.com/questions/12634/… $\endgroup$– FedericoFeb 18, 2015 at 12:50
1$\begingroup$ @Pondlife see the wiki link in that answer: numbers are for FTD, letters for FFS. Also 1-3 is EASA, 4-5 is FAA $\endgroup$– FedericoFeb 18, 2015 at 14:23
1$\begingroup$ @Pondlife he applied the easa-regulations tag, so FAA levels don't apply. $\endgroup$– FreeManFeb 18, 2015 at 16:33
Maybe.
From the page linked by falstro above:
These include the ability to use cylindrical and spherical projection (as found in large simulators), and the ability to drive real Garmin 1000, Garmin 430, Garmin 430 WAAS, Garmin 530, and Garmin 530 WAAS units.
Pictures are included of a particular setup. The large projection format allows all-around visuals. The simulator can drive real Garmin devices, not just replicas. They recommend this vendor for FAA approved hardware (and for $2,100 I would hope a yoke could be FAA certified).
You can use an IOS even with the personal license for the simulator, on the same computer or a separate one.
X-Plane also explains that only the complete hardware+software combination can be certified for use as an FAA approved flight simulator. So it may be easier to just buy a package from a company like PFC, which has the combination already certified. They offer BATD and AATD simulator setups that use X-Plane.
If you need more information, you can contact X-Plane via the link on the same site linked above. They do not keep track of what people use their professional licenses for, but they may be able to comment on what level of certification is achievable.
To a limited extent, yes. Lower level devices such as an FNPT navigation trainer could be driven by an X-plane aerodynamic model and I believe some have achieved accreditation. For higher level devices such as the letter simulators, the issue is that the simulator model response must accurately match actual flight data. X-plane can get pretty good results from only a limited set of geometric data, however matching actual flight data is such a complicated multidimensional 3-D exercise that linearised assumptions are of very limited value.
