We have seen that after an emergency landing when the airplane needs to be evacuated promptly, evacuation slides get deployed immediately. I am not sure if normal air is being inflated in those slides or do they use some other gas in them?
1 Answer
They are filled with carbon dioxide, oxygen and nitrogen. See here for reference.
From the linked article:
Slides inflate with an initial boost from a canister of compressed carbon dioxide and nitrogen. The canister provides only about one-third the volume needed to inflate the slides. The remaining volume is supplied by ambient air, channeled into the slides through aspirators.
When the inflation mechanism is triggered—by a lanyard pulled by the slide as it tumbles from its storage case—gas from the canister accelerates through the aspirators at high speed, creating a vacuum that sucks ambient air into the aspirators through louvers. When the slide is fully inflated, the louvers close.
5$\begingroup$ @GdD: Mostly, but the initial compressed gas which provides the energy for filling is not air, but an oxygen-free mixture of carbon dioxide and nitrogen. $\endgroup$ Feb 12, 2015 at 10:09
$\begingroup$ The way ambient air gets sucked in by the compressed gas flow is called ventrui effect. $\endgroup$ Feb 12, 2015 at 18:43
1$\begingroup$ @JustinKiang ... almost: It's called Venturi effect, after Giovanni Battista Venturi. $\endgroup$ Feb 12, 2015 at 18:45
