27
  • Shouldn't aircraft be able to withstand winds of up to 100 mph? When flying the wind is at a much higher speed than that.
  • Shouldn't they be able to take-off through fog using instruments alone?
  • Shouldn't they be able to take-off on a slippery runway, since the wheels are not powered.
    $\begingroup$ One point that answers have not yet addressed is the requirement to brake in the case of an aborted take-off. $\endgroup$ Jan 5, 2022 at 14:18
10 Answers 10
29
Wind
The problem with wind is that it can be from any direction, not necessarily the direction of the runway. When the wind is coming from the side instead of straight ahead, it is called a crosswind. This means that landing aircraft have to point into the wind to remain lined up with the runway. The slower they are flying, the further to the side they must point the nose. Airliners are designed to land in these conditions, but it requires more skill to do it well. The control inputs required to compensate for a crosswind affect aircraft on takeoff as well, as then must work harder to stay lined up with the runway and stay level through lifting off. High winds tend to come along with gusts, which makes it even harder to control an aircraft. Aircraft during flight are flying faster, so changes in wind are less problematic. Once they are flying slower, the wind is much larger compared to the aircraft's speed, and control is much more critical during landing. Aircraft have crosswind limits, and even below those limits, aircraft may need to go around from a landing attempt, which introduces delays.
Another issue is wind shear, which is when the direction and/or speed of the wind quickly changes. A change of 40 knots at higher speeds is turbulence. During landing or takeoff, it can cause the aircraft to stall and crash.
Visibility
Aircraft can certainly use systems like ILS that allow them to take off or land in low visibility. However, there are many limitations with these systems. The crew must be trained to use them, the aircraft must be equipped to use them, and the airport must be equipped with them. However, when the pilots are relying on instruments, they no longer are able to see hazards like usual. Because of this, separation requirements are inreased in these conditions, which means an airport can't handle as much traffic.
Water
It's true that aircraft wheels are not directly powered. However, traction is still very important during braking, since aircraft can hydroplane just like a car can. This means aircraft need more distance to stop, and can slide off the runway if they lose traction. Frozen water in the form of ice or snow makes a plane even more difficult to steer or stop.
Combine all of the above (a typical storm that would cause delays at an airport), and you can see why airports delay flights or close when conditions get worse.
    $\begingroup$ Also note the effects of snow, ice, and rain. Too much snow/ice on the wings, and your airplane will crash into the Potomac (real case). Too much snow on the runway, and you might not be able to gain flying speed. Icy or wet runway, crosswinds could push you off the runway before you're going fast enough to have control authority. I believe a really heavy rain could even stall the engines, though the only cases I recall involved flying into thunderstorms. And so on. The point is, why take the risk? $\endgroup$
    – jamesqf
    Feb 11, 2015 at 21:09
  • $\begingroup$ Keep in mind that airports typically never close, at least not due to weather. Airlines can cancel flights and pilots can choose not to land/takeoff from an airport, but the airports themselves usually never close due to weather. Controllers can make advisories saying that aircraft might not want to land at an airport, but they can't directly stop flights from landing at the airport. $\endgroup$
    – panoptical
    Feb 13, 2015 at 22:17
  • $\begingroup$ Add to all this that even if the visibility goes to 0 and/or ceiling comes down to ground level, you can still take off (talking about the USA) if you are flying Part 91 (set of laws to fly by). It is everything but safe though, and in an emergency you will probably not make it back safe. Systems like ILS or VOR approaches have limitations. The ILS usually requires you to see the runway environment (FAR §91.275) 250ft AGL, so you need to have some kind of minimum visibility/ceiling above AGL to land! $\endgroup$ Feb 17, 2015 at 23:08
19
Adding to what the others have mentioned, bad weather is often a combination of low visibility, low ceilings, precipitation, high winds and lightning.
Visibility and ceilings
As mentioned in @fooot's answer, ILS is available to land when in these conditions. Every airliner and crew (and just about every airport they'd go into) is trained and equipped for ILS operations. A standard ILS approach is good in weather down to 200 ft ceilings and 1800 or 2400 ft visibility along the runway (RVR). Further airplane and airport equipment and aircrew training can allow ILS category II and III operations, which reduce these numbers (cat II is 100 ft vertical visibility and RVR 1200, cat III goes down to essentially no visibility).
To takeoff, a 2 engined airliner needs 5000 ft RVR (1 mile vis) normally. Airport lighting and airline opspecs can reduce this as low as RVR 300.
Wind
High winds are fine, but can make the landing more challenging. When the winds are strong and particularly gusty, a lower flap setting can be used to land and a faster approach speed flown. This will, however, necessitate a long landing rollout. Exceptional crosswinds can also present problems aligning the aircraft with the runway, and if you can't line up, you can't land (note that some larger airplanes can land in a crab and do not need to align with the runway until the main gear are on the ground).
Runway condition
You mention the wheels are not powered, and this is true. However, the friction between the runway and the contact patch on the tire is the only thing keeping the airplane on the runway in strong crosswinds, so you need friction to land (or takeoff) if there is a crosswind component.
Anything reducing friction is problematic (rain, snow, ice, rubber, etc), With high water you risk hydroplaning and this (or snow/ice) can lead to departures from the runway sides or an overrun if braking action is insufficient due to lack of friction. Ice needs to be chemically treated and snow must either be treated or plowed at regular intervals (while it is snowing). Ground handlers at the airport must also have deice fluid and the equipment to apply it to aircraft available for operations in snow.
Lightning
When lightning is in the vicinity, ground crews go inside as it is a deadly hazard to be on the ramp in those conditions.
Summary
All of these things contribute to lowered arrival rates into the airport and as conditions deteriorate you reach a point where you are spending more time dealing with keeping the airport open than departing airplanes and it makes sense to close the airport temporarily.
  • $\begingroup$ you mean aircraf must carry deice fluid to operate? $\endgroup$
    – vasin1987
    Feb 22, 2015 at 15:14
  • $\begingroup$ @vasin1987 No, either the airport, airline or FBO will take care of deice fluid and application. $\endgroup$
    – casey
    Feb 22, 2015 at 18:18
  • $\begingroup$ Well, the runway condition paragraph confuseme a bit :) $\endgroup$
    – vasin1987
    Feb 23, 2015 at 1:33
  • $\begingroup$ @vasin1987 the airport is responsible for keeping the runways maintained so that aircraft can operate on them. $\endgroup$
    – casey
    Feb 23, 2015 at 1:34
11
The wind should be coming from the right direction and be reasonably steady. Gusting crosswind is a very dangerous thing.
Also it's not just the planes that need to be out in the cold wind but also the ground crew, if you force them to work in such condition you will get unions on your doorstep, unions.
On takeoff you need to maintain the center line, if you deviate a bit the plane will plough into the grass next to it and you will not be flying today.
In order:
  • If the wind were exactly aligned with the runway this might be theoretically possible. Maybe. But, the wind never directly lines up with the runway, and a 100mph crosswind would blow the airplane right off the runway before it ever got off the ground, causing it to crash.
  • They can, though it's better if you can at least see the runway lights. What is actually impossible is taxiing, there's no system that allows you to follow taxiways to the terminals with no visibility.
  • Again, yes, they can use the runway so they can take off. But, when they land, they do use their brakes to stop. If their tires get no grip, the planes would generally slide off the runway (an no, engine braking is not powerful enough to stop a plane on their own.) So having no traction on the runway may not stop you from taking off, but it will stop you from landing.
These are some of several reasons weather can shut down an airport, though there are several more. You might considering asking about other conditions in separate questions though.
  • $\begingroup$ To point #2, airports with SMCGS installations and low visibility taxi plans can handle ground movements in extremely low visibility. $\endgroup$
    – casey
    Feb 11, 2015 at 20:47
  • $\begingroup$ @casey huh, didn't know. I need to ask a question about that. Is this commonly installed on planes and commonly had at airports? $\endgroup$
    – Jae Carr
    Feb 11, 2015 at 20:49
    $\begingroup$ There is no airplane installation, just charts for the taxi plans. It is common at large airports (nothing too special, just taxi routes with high intensity centerline lights and various other lights). In general it is likely found at any airports that do low visibility ops (rvr300/500/600/1000 takeoffs and cat II and III landings). $\endgroup$
    – casey
    Feb 11, 2015 at 20:51
    $\begingroup$ Just because you can take off on a runway isn't good enough. In an emergency, you may need to return to the airport. If the conditions at the airport aren't also safe for landing, then you won't be allowed to take off. $\endgroup$ Jan 5, 2022 at 20:17
Wind
Can the airframe withstand it? Sure. They deal with twice that in the jet stream almost daily. Can they land or take off in it? Not so much, especially if the wind is not straight down the runway (which it almost never is.) Every aircraft has a maximum crosswind component in which it can complete a safe takeoff or landing roll. I'm not aware of any of them near the 100 mph figure. What happens when you try to take off with a crosswind component that is too high? Well, possibly something like Continental Airlines Flight 1404, which got blown off the side of the runway on takeoff in Denver after it had already accelerated above 100 knots. Everyone survived, but the Captain as well as another person sustain critical injuries and the aircraft was destroyed.
The worst part about winds from storms, though, is that they tend to be very gusty with rapid changes in both magnitude and direction. Say you're flying a final approach and you suddenly encounter a 50 knot tail wind. Your wings just stalled and, if you're low enough and/or the gust lasts long enough, you just crashed short of the runway. Also, sudden changes in crosswinds can cause runway excursions.
Thunderstorms are also capable of producing a nasty type of sudden downdraft called a microburst. These are particularly nasty to encounter at low altitude. As you approach a microburst, it causes you to have a sudden strong headwind (and, thus, higher airspeed,) which suddenly increases the lift of the wings, while also slowing down the ground speed of the aircraft. Pilots may naturally compensate for the increased airspeed by reducing power. This then becomes a huge problem seconds later when that headwind vanishes and the wind is instead pushing the aircraft straight downward, causing it to lose altitude quickly. To make a bad problem worse, as the aircraft flies out of the microburst, it now has a sudden tailwind, which quickly decreases the airspeed, causing the wings to produce significantly less lift and perhaps even stall. Encountering such a microburst on short final to DFW near a thunderstorm caused the crash of Delta Air Lines Flight 191 in 1985, one of the most deadly aviation accidents in U.S. history.
Visibility
Shouldn't they be able to take off through fog using instruments alone?
Sure. They do it all the time (in the case of airliners, at least.) Visual flight rules are not allowed in fog, but all airliner flights use instrument flight rules anyway. Sometimes they execute visual approaches, but nearly every airport that handles airliners and all airliners and airline flight crews have the ability to perform an instrument landing. Many commercial airport runways (and most airliners) are equipped and certified for fully automated landings. Takeoff doesn't even need that.
General Aviation is another matter here, though. Pilots and/or aircraft not certified for instrument flight rules cannot operate in fog. While many GA pilots and aircraft are certified for IFR, many also aren't. Flights not using IFR must be operated under Visual Meteorological Conditions, which generally require that aircraft can only land or take off when the cloud ceiling is more than 1,000 feet above the ground level and horizontal visibility is at least 3 statute miles (at least in the U.S.)
Traction
Shouldn't they be able to take-off on a slippery runway, since the wheels are not powered?
Not really, no. The big problem here is not the lack of ability to accelerate with the wheels, but rather the lack of directional control and the inability to brake. On both takeoff and landing, the aircraft relies on the contact of the landing gear with the pavement to maintain directional control. Also, traction is also obviously required to use the wheel brakes (which provide the primary stopping force on airliners.) Ice is particularly nasty about causing loss of directional control on the runway. For example, Tower Air Flight 41, a 747 departing JFK for Miami, lost directional control on takeoff due to ice, resulting in a runway excursion. There were no fatalities, unless you count the 747 itself, which was damaged beyond repair.
If you look at historical behavior, you'll find that airports in the 1970s and 1980s generally didn't close for bad weather. Stapleton Airport in Denver for example, never closed for weather a single time until a major blizzard in 1982.
I believe the reason they do now is liability law. Though they could theoretically continue to operate in most bad weather with a 99% chance of safety, that 1% chance of having an accident and facing an expensive lawsuit from injured passengers or surviving families causes them to err on the side of caution.
    $\begingroup$ Can you please add a reference about Stapleton Airport not closing because of weather until 1982? $\endgroup$
    – Farhan
    Feb 12, 2015 at 17:29
  • $\begingroup$ There are many articles about the blizzard of 1982, which I'm confident was the first full weather closure of Stapleton, but I can't seem to locate any articles that specifically mention that fact. nytimes.com/1982/12/28/us/… $\endgroup$
    – barleyguy
    Feb 12, 2015 at 22:49
If 100 miles an hour generates enough lift for the aircraft to fly, then a wind gusting 100 miles per hour might result in the aircraft taking off while the passengers are still climbing the steps.
Kites fly without any speed relative to the ground. When the wind blows strong enough, so do aircraft. In weather like this the aircraft are either secured to the ground with tie-downs or taken indoors.
(Not that tie-downs always work.)
  • $\begingroup$ While a PA-28 can fly at 100 mph (or 45 mph, for that matter,) almost no airliners can. I believe most airliners will have stall speeds above that, even when empty with full flaps. That picture is definitely a good illustration of what wind can do to a light aircraft, though. $\endgroup$
    – reirab
    Feb 12, 2015 at 18:46
    $\begingroup$ "Ugh... what did I do last night?" $\endgroup$
    – Vikki
    Mar 23, 2019 at 21:36
A point to bear in mind with all of these, is that it doesn't take much for flight cancellations if your airport is already running very close to capacity with no time to makeup earlier delays.
This notably is the case with Heathrow where NATS (UK ATC) will be trialling time based separation over the current distance based separation between aircraft. Here's a good explanation from them about the impact of headwinds on landing rates and how measures like this can mitigate some of these impacts: http://www.nats.aero/tbs/
All of the comments about weather describe why the pilot of an aircraft might not want to land when certain phenomena are present. But this does not mean the airport is closed!.
Airports themselves "close" very very rarely. When they do it is almost always because there is some problem with the runways. Most often this is contamination from snow and ice, which reduces traction (and therefore braking action) to unsafe levels that preclude any aircraft operation whatsoever. Other issues could include damage to the runway, a disabled aircraft on the runway, or in the case of grass strips a runway that is too waterlogged to safely support an aircraft.
For almost all other meteorological phenomena, the airport is still technically "open" and available for a pilot to use if they desire; it is up to the pilots themselves to determine if they feel comfortable using the airport for departure or landing. Sometimes there are regulations (such as 14 CFR 121.651) that dictate certain weather minima, and sometimes an air carrier's Operations Specification (which is a pre-approved document that is binding on the pilots) may dictate even more conservative minima, but this does not mean that the airport is closed.
Ceiling and visibility conditions could be so bad that pilots cannot visually acquire the runway environment and therefore are unable to continue to land, but this does not mean that the airport is closed. Some aircraft and air carriers are certified to conduct "zero/zero" landings, and others are not.
Air traffic control can enforce a ground stop to an airport, meaning that flights bound to that airport are not issued takeoff clearances, often due to unsustainable volume (amount of inbound flights); the volume is often unsustainable due to poor weather resulting in more spacing required on final and more go-arounds, but could be because of other reasons like higher-than-usual demand (such as all the private flights going to Florida around the holidays). But this still does not mean that the airport is closed. An aircraft in distress would still be allowed to attempt an approach.
All of these questions answer from the point of view of the plane. Can it land, can it take off, can the pilots see, can they control the plane, etc. But there is another aspect not yet mentioned: ground staff.
It's incredibly common for long delays to be caused by thunderstorms because it's not safe for anyone to be outside during active lightning. This means the people who hold the sticks to show the planes where to park, the people who hook up the fuel trucks, the luggage handlers - dozens of people many of whom are handling dangerous equipment, and all of whom have to stay inside until the lightning stops. An airport may stop allowing landings and takeoffs even when the planes would have no trouble landing or taking off because it's not safe for ground crew to be out there.
    $\begingroup$ Multiple answers mentioned this already. They were posted the same day the question was asked, over 9 months ago. Don't resurrect old questions if you're not adding something new. $\endgroup$
    – nobody
    Nov 30, 2015 at 0:47
  • $\begingroup$ Also, this factor doesn't technically close the airport, just the ramp. Aircraft which have already pushed back can still take off in lightning and arriving aircraft can still land. They just can't push back a departing aircraft or dock an arriving one until the lightning stops. I suppose powerback is possible in this scenario if they've already undocked the jet bridge, disconnected ground power/air, and removed the chocks, though. $\endgroup$
    – reirab
    Aug 14, 2016 at 22:28
  • $\begingroup$ @nobody -- I only see one existing answer mentioning lightning -- this one aviation.stackexchange.com/a/12624/34686 -- $\endgroup$ Jan 5, 2022 at 15:02
  • $\begingroup$ Worrying about lightning harming ground crew on the ramp area seems unrealistic to me -- I mean it's one thing if you are on the edge of a cliff ( a favorite target for lightning) or standing up in the middle of a field far from any tall object-- but airports are full of tall objects that will attract lightning preferentially to the ramp area-- $\endgroup$ Jan 5, 2022 at 15:06
