How do modern aircraft steer on the ground? Do they have a steering wheel which moves the front wheel (left/right).
I see that there is a Tug vehicle which pushes the aircraft backwards, so the aircraft does not have a reverse gear for sure.
Does the aircraft use the Engine thrust to move forward on the ground or does it have separate motor which propels the wheels?
All of these methods are used.
Nosewheel steering is common on most commercial aircraft using a tiller. Rudder, differential braking, differential thrust and even motors in the wheels (experimental only as far as I know) are also used, as seen in this video.
Engine thrust is used to move forward but differential thrust might also be used when negotiating tight turns. (Details here)
  • $\begingroup$ You beat me to the answer. Want to expand yours by adding a part about electric taxi motors being tested? I intended to mention that. $\endgroup$ Commented Feb 2, 2015 at 9:41
  • $\begingroup$ @Simon Thanks for the answer and the Wiki link. I think the Wiki page answers lot of my queries. $\endgroup$
    – ViSu
    Commented Feb 2, 2015 at 10:50
