I can think of three reasons to use an updraft carburetor in a single-engine GA airplane:
Anti-flooding:
The float-bowl regulator in your carburetor is cheap and simple, but it is far from perfect under all conditions. Short periods of zero-G or negative-G operation, caused by a quick dive, turbulence, or even bumping over uneven ground, can jiggle the float and spill liquid fuel into the venturi.
In a downdraft or sidedraft carburetor, this liquid falls into the intake manifold and wets the interior walls and may get into the cylinders, causing an over-rich mixture condition. The engine is said to be "flooded" and will not run until the liquid is cleared out.
With an updraft carburetor, the spilled fuel tends to fall out before it can foul anything.
Gravity feed:
If your aircraft has fuel tanks higher than the carburetor when in cruise attitude, you may be able to remain under power if your fuel pump fails. An updraft carburetor can be mounted lower in the engine compartment than sidedraft or downdraft types; in fact, it is usually under the engine.
Early automobiles did this to avoid the need for a fuel pump; fuel was fed by gravity from a fuel tank higher than the carburetor, e.g. just below the windshield. The lower the position of the carburetor, the deeper the fuel tank could be.
Convenience:
If you look inside the cowling of most GA planes, you will see much more space under the engine block than above it. That seems to be the best place for lots of auxiliary equipment and attachments, including the carburetor and air filter.
