10
As far as I understand, two of the reasons how an airfoil generates lift are Coandă effect and downwash. However, if there is upwash near the leading edge, why isn't an airfoil rotated by the two forces (upwash at the front and downwash at the back of an airfoil)?
  • $\begingroup$ Airfoil lift and Coandă effect are similar but strictly distinct phenomena. Coandă effect describes situation when a distinct stream flows flows around an object surrounded by static, possibly different, fluid. On the other hand lift occurs with homogeneous oncoming flow. $\endgroup$
    Jan 13 '15 at 18:01
  • $\begingroup$ It does rotate:en.m.wikipedia.org/wiki/Pitching_moment $\endgroup$
    – tpg2114
    Jan 13 '15 at 18:14
  • $\begingroup$ Ditto tpg2114. For example, on most modern airliners the wing in flight causes a negative pitch (nose down) rotation. In level flight the horizontal stabilizer produces a down force (positive pitch with longer moment arm) to balance these rotations. $\endgroup$
    – mrbcuda
    Jan 13 '15 at 22:02
  • $\begingroup$ @mrbcuda That pitch-down moment is caused by the center of gravity being forward of the center of lift (i.e. wings are aft of the CoG,) not by forces acting on the wings themselves in different directions. If the wings were positioned such that the CoG coincided with the CoL, then that moment wouldn't exist. Similarly, if the wings were positioned such that the CoG were forward of the CoL, there would be a pitch-up moment. $\endgroup$
    – reirab
    May 7 '15 at 20:23
11
There are no two (aerodynamic) forces. Force is not caused by the up- or downwash itself, but by the change from up- to downwash. The air is only accelerated downward and this change in it's momentum causes an upward force on the wing everywhere, there is no aerodynamic down force. Due to the pressure distribution however the centre of lift is about quarter-chord for subsonic airfoils and changes somewhat with changes in attitude.
There however obviously is a down force, gravity. If the centre of gravity and centre of pressure are offset relative to each other, there is a moment that rotates the aircraft. That's why a plane needs horizontal stabilizer with elevators that allow shifting the centre of lift by adding a bit of controllable lift far from the centre of lift of the main wing.
It does rotate. In fact, in aerodynamics, this rotation force has a name: pitching moment. Pitching moment changes depending on the angle of attack.
Airfoils can be designed with almost any pitching moment and still generate lift, from positive (trailing edge rotates upwards as you describe), to zero (no rotation) to negative (trailing edge rotates downwards). In general, high lift airfoils have positive pitching moment (because, as you noticed, downwash caused by the Coanda effect increases lift). But zero and negative pitching moment airfoils are useful for tailless and flying wing aircraft. Helicopter blades are long, narrow and flexible so must use zero pitching moment airfoils to prevent them twisting.
If you use an airfoil with a positive pitching moment you need something to counter the rotation. For most aircraft the solution is the horizontal stabilizer (the tail). An alternative solution is the canard.
For chevron shaped (V-shaped) flying wings and tailless planes the solution is to twist the wing (in regular planes it's called washout but flying wing designers call it "twist"). The twist causes the wing tips to have less angle of attack (sometimes negative) so that the overall rotation force for the entire aircraft is zero.
Perhaps you're thinking of something like a fanwing, which incorporates both centrifugal fans and an airfoil into the wing
  • $\begingroup$ Pretty interesting concept, thanks for pointing it out. I've been thinking about designs with a compressor spanning the almost entire wingspan before (prior interest), but while they work, speed is an issue. Wonder if the fanwing people can find a market. $\endgroup$ Jan 13 '15 at 19:58
You are right, lift is concentrated in the forward part of an airfoil, especially at high angle of attack. If you take a single wing and drop it, it will start to rotate around its spanwise axis quickly. This effect is called autorotation (not to be confused with autorotation in helicopters, though!). Model aircraft pilots should have seen that before: When a model breaks apart in midair, its wing will in many cases autorotate to the ground.
In an airplane this can be avoided by shifting the center of gravity near the center of lift and by adjusting the lift distribution either with a tail surface, a canard or with wing flaps such that the center of lift is exactly over the center of gravity. Flying wings can do this without a separate tail surface, but need special airfoils which show little change in the location of the center of lift over angle of attack.
Below you see the pressure acting on an airfoil symbolized by arrows (yes, that is XFOIL at work), and arrows pointing at the airfoil indicate pressure higher than ambient air pressure, and those pointing away from it indicate suction. Their length is proportional to the magnitude of either pressure or suction.
Eppler 502 mod with arrows indicating surface pressure
This shows that the forces in the forward part of the airfoil are more intense than those in the rear part. The aerodynamic forces which depend on the angle of attack are focused at the quarter chord point, and without added balancing masses of a fuselage and engines, will be forward of the wing's center of gravity.
Of course, this is strictly true only as long as we have no flow separation. Once rotation starts, separation is unavoidable above the maximum angle of attack. However, inertia will keep the wing spinning until the trailing edge points forward and a similar pressure distribution develops. This gives the rotation another push and keeps the wing spinning over a full revolution, and the whole process starts over.
Because the horizontal stabilizers provide a counter force to the plane in its entirety so the pitch remains stable.
If the airfoil is cambered (in other words unsymmetric looking sideways) it does indeed rotate. This is why the control surfaces are needed with a preferably long moment arm and why building flying wings is difficult.
    $\begingroup$ There is not really big difference between cambered airfoil and noncambered one flying with non-zero angle of incidence. $\endgroup$
    Jan 13 '15 at 14:57
