14
The ASK-21 is mainly a fibreglass construction.
However, the bearings for the airbrakes and their control rods are fitted into small pieces (some 10 cm wide) of what seems to be plywood molded into the fibreglass.
The following picture shows the plate holding the bearing for the airbrake, seen from the rear side in the space in the fuselage where the wing spars are joined. The bolt that sticks out holds the bearing of the linkage that transfers the brake movement to the rods in the wing.
The plywood plate holding the bearing for the airbrake, seen from behind
The last picture shows the bearings in the wing where the rod to lift the actual air brake is fastened.
The bearing for the rod that lifts the air brake
What is the reason for this choice of material - could the bearings not be fitted into the fibreglass structure without extra pieces of plywood?
  • 9
    $\begingroup$ An image of the bearing would help illustrating this question no end. $\endgroup$
    – yankeekilo
    Jan 12, 2015 at 13:41
  • $\begingroup$ In the ASK-21s I know the steel tubing is only used to integrate the landing gear. The wing box is all glass fiber epoxy. $\endgroup$ Jan 12, 2015 at 20:02
  • $\begingroup$ @yankeekilo Point taken - if I can get one I'll post it. $\endgroup$
    – Monolo
    Jan 13, 2015 at 19:54
  • $\begingroup$ @PeterKämpf interesting. I'll look at it in more detail when I get a chance. $\endgroup$
    – Monolo
    Jan 13, 2015 at 20:24
  • $\begingroup$ Whoa - bad corrosion on the brass bushings for the speed brake. It seems you didn't dry them soon after getting soaked in rain. $\endgroup$ Jan 19, 2015 at 7:14
16
This use of plywood is not ideal, but it works. The wood soaks up the epoxy and becomes an integral part of the fiberglass construction, and is easy to mold, so laying up the same geometry from glass fibers alone would be much more laborious.
Also, plywood is reasonably isotropic, at least in the two directions of the plywood layers. If you want to achieve similar isotropy with glass fibers, you need to interweave them - just wrapping one roving around the bearing will not do.
You could use other materials - aluminum would do, but doesn't bond as well to the epoxy resin. That Schleicher uses plywood has historic reasons. They used to build gliders with wood, some had steel tube fuselages, but wood was their primary construction material. When they started to build glass fiber gliders (the first was the ASW-12, which was a commercial version of the D-36, on which Gerhard Waibel cut his teeth as a glider designer and won the German gliding championship in 1964) they used what they knew best. And it worked.
    $\begingroup$ I would not globally agree with "not ideal". It is a proven, robust and economic solution. $\endgroup$
    – yankeekilo
    Jan 12, 2015 at 16:09
    $\begingroup$ @yankeekilo; You're right, but it has lower compression strength than tensile strength. This shifts the failure point lower than ideally possible. I would prefer a metal structure welded to a large, perforated base plate which then is laminated between the layers of the glass fiber structure. In case of carbon epoxy, this metal is ideally titanium. $\endgroup$ Jan 12, 2015 at 19:59
10
For some bearings, you need a sufficent thickness of the socket and supporting structure to deal with bending moments on the rods/bolts, plus you need to transfer the point loads into the wing structure.
Plywood is well suited for this task, while being lighter, cheaper and easier to build and machine than aluminum or fibre-reinforced plastics. Together with the top glass laminate you get a lightweight, yet sturdy structure (essentially a sandwich). As already stated, (ply-)wood is a surprisingly fabulous material.
Making a thick spot in fibreglass (to support a point load) is actually a little tricky.
The resin produces heat as it cures, so if you have too much in one spot it can get so hot that it produces smoke. Instead you need to build it up in layers, with a wait of a few hours between each set of layers. Too fast and it overheats, but you also can't leave it too long or it won't bond well to the cured resin. If you don't plan well, you end up working through the night.
It's much faster and easier to slap in a block of wood, and do the whole job in one go.
