The Evektor Harmony LSA & RV-12 SLSA have all the necessary equipment to be certified for IFR flight, except the only engines allowed for purchase are the Rotax 912 ULS & iS. These engines are not allowed in IMC.
Question: Can these planes be certified for IFR, despite the IMC limitation?
  1. if no, can they be used for training for one's instrument rating and for the instrument rating checkride?
  2. if yes, then if one were to be flown into IMC, would be this be a legal violation or a warranty violation?
  • $\begingroup$ Possible duplicate of: aviation.stackexchange.com/a/849/167 $\endgroup$
    – Steve V.
    Jan 12, 2015 at 2:55
    $\begingroup$ @SteveV. The link doesn't address the above questions unless I'm missing something. From the reference, "prohibit the use of a Rotax engine at night or in IFR conditions". Does this mean that a Rotax 912ULS cannot be used be used for IFR flight plans in VMC? Can it be used for IFR training in VMC? $\endgroup$
    – jt000
    Jan 12, 2015 at 3:18
  • $\begingroup$ The other link answers your question $\endgroup$
    – rbp
    Jan 12, 2015 at 6:03
    $\begingroup$ IFR and IMC/VMC conditions are two independent concepts, and if the aircraft is certified for IFR flight, then you can fly it under IFR. However, if there is another limitation that prevents you from flying in IMC, then you are not allowed to do so, even if you are allowed to fly under IFR. $\endgroup$
    – Lnafziger
    Jan 12, 2015 at 6:14
  • $\begingroup$ The other answer does cover most of this, but it doesn't cover the question about instrument training, does it? $\endgroup$
    – Jay Carr
    Jan 12, 2015 at 9:05
No
Refer to FAA Order 8700.1:
B.  Type Certificate Data. Appropriate type certificate data will indicate whether the aircraft meets the requirements for IFR operations.
(1) Section 91.9(a)prohibits aircraft operations without compliance with the operating limitations for that aircraft prescribed by the certificating authority.
Yes, as per FAA Order 8700.1:
9.  USE OF AIRCRAFT NOT APPROVED FOR IFR OPERATIONS UNDER ITS TYPE CERTIFICATE FOR INSTRUMENT TRAINING AND/OR AIRMAN CERTIFICATION TESTING. The following paragraphs are intended to clarify the use of an aircraft not approved for IFR operations under its type certificate for instrument flight training and/or airman certification testing.
A.  IFR Training in Visual Meteorological Conditions (VMC). Instrument flight training may be conducted during VMC in any aircraft that meets the equipment requirements of part 91, 91.109 , 91.205 , and, for an airplane operated in controlled airspace under the IFR system, 91.411 and 91.413 . An aircraft may be operated on an IFR flight plan under IFR in VMC, provided the PIC is properly certificated to operate the aircraft under IFR. However, if the aircraft is not approved for IFR operations under its type certificate, or if the appropriate instruments and equipment are not installed or are not operative, operations in Instrument Meteorological Conditions (IMC) are prohibited. The PIC of such an aircraft must cancel the IFR flight plan in use and avoid flight into IMC.
For example, you can obtain an Instrument--Rotorcraft in an R44, even though its not legal in IMC.
Although the R44 IFR Trainer was designed for instrument flight training, it is not approved for actual IFR operations. While student pilots are flying on instruments, the instructor must act as the safety pilot and operate only under VFR conditions.
This would be a legal violation of 91.9(a)
91.9(a) Except as provided in paragraph (d) of this section, no person may operate a civil aircraft without complying with the operating limitations specified in the approved Airplane or Rotorcraft Flight Manual, markings, and placards, or as otherwise prescribed by the certificating authority of the country of registry.
    $\begingroup$ wrong. you can file an IFR flight plan for training purposes so long as the aircraft meets the regs and you remain VMC $\endgroup$
    – rbp
    Jan 18, 2015 at 15:39
    $\begingroup$ Interesting... Would I put "Training flight, VMC only" in the remarks section for this or just mention it when opening? $\endgroup$
    – jt000
    Jan 18, 2015 at 15:56
    $\begingroup$ they're not under any obligation to keep you in VMC if you're on an IFR flight plan. that's your responsibility, so don't file unless you're sure you can maintain VMC throughout the flight. As it says in the answer, you must have a IFR-rated pilot acting PIC. $\endgroup$
    – rbp
    Jan 18, 2015 at 16:02
    $\begingroup$ That makes a lot of sense. I assume it would be pretty bad form to cancel IFR if they tried to route you into IMC. In Seattle winters, you're almost always 1000' below ceiling, so I could see this being a common occurrence if one were to attempt this out there. $\endgroup$
    – jt000
    Jan 18, 2015 at 16:17
    $\begingroup$ You are PIC. You can cancel anytime you want, so long as you can maintain VFR. In fact, canceling as the weather deteriorates in the direction of flight and turning back towards VFR puts less load on the controller and he'll be thankful to get a bug smasher off his screen. Its much harder the other way around, flying VFR and asking for a "pop-up" IFR clearance puts more, unexpected workload on a controller, and it can take a few minutes before he has time to get you into the system. $\endgroup$
    – rbp
    Jan 18, 2015 at 16:23
