Pilots have to be able to handle a wide range of emergencies in the air. For powered aircraft, the obvious example to me is recovering from an engine failure, but obviously this can't happen on an unpowered glider. Many gliders have no electrical systems, so an electrical failure can't happen. A stall, I believe, can, and I assume the recovery would be similar to in a powered aircraft. What other emergencies should a glider pilot be able to handle? I'm especially interested in any emergencies that powered aircraft don't have to deal with.
1$\begingroup$ I imagine a glider could have every emergency a powered aircraft could have, with the exception of an engine failure or fuel exhaustion situation: You could still have an electrical fire/smoke condition, stall/spin, inadvertently fly into IMC, etc.) You could also fail to find enough lift and have to land somewhere that's not an airport, which is kind of like fuel exhaustion, but that may not quite rise to the definition of an "emergency". $\endgroup$– voretaq7Dec 18, 2014 at 22:05
4$\begingroup$ most gliders don't have electrical systems. maybe your iPhone battery can catch fire. $\endgroup$– rbpDec 18, 2014 at 22:11
$\begingroup$ @rbp true, but it's also fair to say most gliders also don't have engines and fuel tanks except the ones that do :-) $\endgroup$– voretaq7Dec 18, 2014 at 22:36
$\begingroup$ interestingly, you don't needs ASEL to fly a powered glider, even one as fancy as an S-10VT: stemme.info/aircraft/peak-performer. but you do need an self-launch endorsement faa.gov/documentLibrary/media/Advisory_Circular/ac61-94.pdf $\endgroup$– rbpDec 18, 2014 at 22:43
$\begingroup$ "I'm especially interested in any emergencies that powered aircraft don't have to deal with". Powered aircraft can become gliders (intentionally or accidentally). $\endgroup$– geometrianDec 19, 2014 at 7:54
The number one emergency in a glider is a tow rope break at low altitude, less than 200 feet above the ground with no appreciable headwind. Below 200 feet, the proper technique is to land straight ahead, which usually means landing off airport.
Between 200ft and 500ft, it is possible to make a U-turn back to the runway, and land in the opposite direction in which you took off. The main hazard with this kind of landing is landing with a tailwind, and once the wheel touches the ground, the flight controls operate in the reverse direction.
Above 500 feet, it is possible to fly an abbreviated pattern and land on the runway you took off from.
Add 50 feet of altitude for each 10 knots of headwind.
Some other tow emergencies are inability to release to tow rope, in which case the tow pilot needs to release the rope on his end; engine failure of the tow-plane; and a double tow rope release failure, which means the glider needs physically break the tow rope (it has a pre-determined breaking strength of 80-200% of the weight of the glider) or to land behind the tow-plane.
You can also run out of altitude and have to land in a field, which is called an "off airport landing." Someone has to come and get you with a trailer, and you disassemble the glider and drive it away. One hazard is the off airport landing in a field, and the farmer comes out with his shotgun.
Other hazards are flying into the clouds or into severe turbulence, which can happen when the glider pilot is flying "wave," a kind of lift generated by strong winds in proximity to mountains.
When thermaling, you are flying very tight steep turns, often with other sailplanes who are also trying to gain altitude. Everyone is supposed to fly the thermal in the same direction, and there is the hazard of colliding with other gliders.
Reference: FAA Glider Flying Handbook - Abnormal and Emergency Procedures
1$\begingroup$ Nice summary; also air-air collisions when thermaling in a gaggle. $\endgroup$ Dec 18, 2014 at 22:12
$\begingroup$ Flight controls do NOT operate in the reverse direction when landing with a tailwind. The relative wind is still from the glider's nose to the glider's tail, but with a tailwind the glider has greater ground speed. It is only airspeed that counts in the generation of lift and control of the aircraft. $\endgroup$ Dec 18, 2014 at 22:14
$\begingroup$ Once the SINGLE wheel touches the ground, right rudder will catch the wind on the right side of the sailplane and attempt to spin the glider counter-/anti-clockwise. both my CFI and DE warned me about it last month when I took my commercial glider checkride, and it happened both times. try it. I've updated the answer to notate that it happens on the ground. $\endgroup$– rbpDec 18, 2014 at 22:20
$\begingroup$ I don't fully get the implication of danger in "tight, steep turns." Are tight steep turns always dangerous, or do they just make flying with a bunch of other aircraft even more dangerous? $\endgroup$ Dec 18, 2014 at 23:42
1$\begingroup$ its called "slack rope," which is when the glider trades off altitude for airspeed, and reduces the distance to the towplane. when this happens, the rope will get a big bow in it. Under normal circumstances, the pilot can remove the slack by yawing towards the bow, allowing the slack to come out gently. To break the rope, the pilot yaws towards the slack, then when the slack almost is almost out, he yaws further away, breaking the rope. $\endgroup$– rbpDec 19, 2014 at 0:05
In addition to the emergencies mentioned by rbp, there's also spin recovery. Presumably power pilots need to know this as well, but it is more relevant to glider pilots because thermalling can take you close to the incipient spin territory. In Australia, at least, real spin recovery is practiced until the pilot is proficient at recovery.
$\begingroup$ Although I did do spin training during my glider, training it's not part of the private or commercial PTS in the USA. It is however in the CFI-G PTS $\endgroup$– rbpDec 19, 2014 at 0:52
$\begingroup$ Yeah, I recall my instructor mentioned it was not routinely taught in the US, abd how odd that is.... $\endgroup$ Dec 19, 2014 at 1:52
$\begingroup$ Did you have to initiate the spin? It's pretty hard to even stall some glider trainers. They just mish, unless you're really crisp $\endgroup$– rbpDec 19, 2014 at 2:17
$\begingroup$ Yes, you learn initiation and recovery. The Australian training fleet had many glider that are spin friendly, though a few need canards fitted to make them enter reliably. $\endgroup$ Dec 19, 2014 at 4:45
$\begingroup$ The purpose of spin training is symptom recognition to prevent dangerous inadvertent spins in low-altitude high-workload situations where recovery from a full spin may not be possible. The otherwise counterintuitive inputs to recover from an unintentional spin are not unique to gliding. $\endgroup$ Aug 5, 2019 at 15:10
Another very important accident that can occur is what I know as the Kavalierstart.
It occurs on winch launches with some airplanes when the pilot is not giving enough nose down command during the first couple of seconds.
The airplane gaining speed really fast will pitch up and as it is going up with a very steep angle, the lift will actually pull in the opposite direction of where the winch rope is coming from. Due to the excessive load the rope will break, and as the hook with which the rope is attached to the glider is before the center of gravity, the missing force of the rope will cause the glider to continue pitching up bringing it into extreme nose up or even upside down attitude (as it is already flying up pretty much vertically). Without the rope pulling the glider it will almost immediately lose its airspeed and drop down.
There is no way over recovering this and it usually ends up in killing everyone on board.
Answering an old question but there are issues with the winch launch that have not been covered; one is a wing drop on the ground run. If the wing touches the ground while being winched then the glider can cartwheel if the pilot is not quick enough or able to pull the cable release. The winch can keep pulling the aircraft until the winch operator spots a problem and stops the launch or the pilot pulls the release. This happened at my club about 3 years ago (2012) with an experienced pilot in a Nimbus 3. He died of his injuries.
There is also the possible issue with cable fouling, although unlikely it is possible in a shallow fast climb to dip the nose on release and impact the cable if the cable parachute has opened. That will ruin your day.
Pulling too far back on the stick on the ground run can cause an overly-quick rotation into a steep climb causing the tail to hit the ground. While removal of the tail will reduce drag considerably it will cause one of two control issues.
In winch launches you are very much at the mercy of your ground crew and winch driver. All it takes is for a misheard instruction or someone to mistake the glider model and you could be launched on the wrong winch setting. An underpowered or overpowered launch can cause a lot of problems for a pilot but then that is why we drill for problems. I have to admit to signalling a launch for the wrong type of glider, thankfully it was spotted by the pilot who radioed a correction but I have seen gliders launched on the incorrect winch setting on a few occasions.
Pilots of Petrol Pigeons don't have a cable to worry about.
Most gliders do have battery and/or solar-powered avionics and comms, so there can be electrical failures. In fact, one must take battery life into account for long flights.
Gliders often fly much higher than other general aviation aircraft, so failure of the oxygen system with attendant hypoxia is a risk.
$\begingroup$ You should answer once, and put all your answers in the same answer $\endgroup$– Manu HNov 14, 2015 at 8:25
Let me add some more possible failures:
- Incorrectly assembled aeroplane ( actual reason for some tragic deaths ). Avoided by following check lists and instructions before even contemplating to start.
- Items dropped in the cockpit may lock up controls ( I did drop a water bottle down among the cables, luckily not locking up the controls )
- In air collision, especially when flying in clouds ( One reason flying in clouds generally not allowed in competitions )
- Heat stroke: the cockpit has plexi glass all around and in sunny weather it will be very warm. Never forget you most important personal safety item, the hat.
- Out of oxygen: we from the "low lands" can not stand any long time up high. Once above 10.000 feet (3.000 meters) we should have Oxygen along. Note that in wave flying a glider might reach 10.000 meters.
- Out of energy, already mentioned in other answers. Pilots train for this and are supposed to commit to landing once reaching minimum height above ground. Add a bit to the minimum when over rocky terrain or over dense woods.
