I know that the A380 has low/med/high RTO auto-brakes. What I'm not sure about is if there's a switch near the thrust levers that can disengage the auto-brakes, other than the switches located on the brake panel.
To put it another way, the A380 has a brake panel where the switches allow you to engage/disengage auto-brakes (either low, med, or high RTO). But in addition to those, is there any other switch that can do the same thing without the pilot needing to take his eyes away from the view outside?
    $\begingroup$ Well, he can tap the breaks. $\endgroup$
    – Hugh
    Dec 14, 2014 at 5:46
  • $\begingroup$ @Hugh yes he can, but it is far more convenient and safe to do it using a button - simply disengages the brake (which already slowed the a/c down significantly, below 50 knt) $\endgroup$
    – ha9u63a7
    Dec 14, 2014 at 20:13
  • $\begingroup$ Tapping the brakes is one. Increasing thrust past CLB (for go-around) is another. And does anybody know whether the brakes normally remain on until the aircraft stops or just until it slows down to taxi speed? I'd expect the later (in which case the autobrakes simply disengage themselves in the usual case), but I don't really know. $\endgroup$
    Dec 14, 2014 at 21:07
  • $\begingroup$ If the pilot disarms the Spoilers it will disconnect the auto-brake. Alternatively, the pilot may disengage the auto brake by setting the AUTO BRK Mode selector to DISARM. $\endgroup$
    – DSarkar
    Dec 15, 2014 at 11:19
    $\begingroup$ @JanHudec I only have experience with the A319/320, and on those, the autobrake operates until disengaged or the aircraft is stopped. Proper procedure is to take over breaking manually before reaching taxi speed. Although I assume the A380 is the same, I cannot say for sure that it operates the same way. $\endgroup$
    – newmanth
    Dec 15, 2014 at 21:54
The A380 has one Takeoff Autobrake setting which is RTO and five Landing Autobrake settings which are BTV, LO, 2, 3 and HI. Some may read that as four plus the BTV, which is a variable deceleration compared to fixed deceleration. As you have noted, these are selected from the Autobrake selector switch.
It is possible to disarm the Autobrake using a number of actions. One or two which have been mentioned already.
  1. The Autobrake selector switch is set to Disarm.
  2. The Brake pedals are depressed with a higher input than the Autobrake setting.
  3. The Spoilers are retracted.
  4. The Autothrust instinctive disconnect pushbutton switch is pressed. These are located at the ends of the Throttle control levers.
  5. The RTO Arm pushbutton switch is set.
FCOM Reference for anyone interested - FCOM/DSC/32/10/30/20/00004244.0002001
  • $\begingroup$ Hello Kamran, welcome to Aviation.SE! Your answer is good as it is, but it could be even better if you would have the FCOM reference for it. $\endgroup$
    – DeltaLima
    Dec 18, 2014 at 8:30
  • $\begingroup$ @DeltaLima Thanks. I am an engineer so I am unaware of the FCOM reference. The ATA reference for anyone interested is 32-42-00 (Normal Braking). $\endgroup$
    – Talha
    Dec 18, 2014 at 9:02
    $\begingroup$ Having an extra engineer here is even better! Thanks for the reference. DL $\endgroup$
    – DeltaLima
    Dec 18, 2014 at 18:50
  • $\begingroup$ @DeltaLima Thanks for the welcome! Will try and get hold of the FCOM reference after the weekend for anyone interested. $\endgroup$
    – Talha
    Dec 18, 2014 at 20:59
  • $\begingroup$ I found the following reference for anyone interested - FCOM/DSC/32/10/30/20/00004244.0002001 $\endgroup$
    – Talha
    Dec 21, 2014 at 7:35
