12
I am currently a private pilot with an instrument rating and multi-engine rating. I own and regularly fly my own twin engine airplane and have been thinking about getting my commercial rating. Part of the PTS requirements for the commercial multi-engine include the emergency procedures for engine out/emergency descents, etc.
Since I have already had a check ride (multi-engine rating) that included ALL of these maneuvers, do I still have to perform these on a commercial multi-engine check ride?
Yes, if this is your initial rating on a Commercial certificate, you have to do all of that rating's required tasks. A checkride for a given certificate is always self-contained. In the case of an additional Commercial rating (ASEL, for example) you can refer to the appropriate "Additional Rating Task Table" and you'll see that some areas are already covered by the existing Commercial rating.
If you look closely, you'll notice that the PTS standards for the same maneuvers are more precise for Commercial than they are for Private. Notice that Steep Turns differ in both bank angle and execution technique:
Commercial (from FAA-S-8081-12C)
Task A: Steep Turns (AMEL and AMES)
References: FAA-H-8083-3; POH/AFM.
Objective: To determine that the applicant:
  1. Exhibits satisfactory knowledge of the elements related to steep turns.
  2. Establishes the manufacturer’s recommended airspeed or if one is not stated, a safe airspeed not to exceed VA.
  3. Rolls into a coordinated 360° steep turn with at least a 50° bank, followed by a 360° steep turn in the opposite direction.
  4. Divides attention between airplane control and orientation.
  5. Maintains the entry altitude, ±100 feet, airspeed, ±10 knots, bank, ±5°; and rolls out on the entry heading, ±10°.
Private (from FAA-S-8081-14B)
  3. Rolls into a coordinated 360° turn; maintains a 45° bank.
  4. Performs the task in the opposite direction, as specified by the examiner.
  5. Divides attention between airplane control and orientation.
  6. Maintains the entry altitude, ±100 feet, airspeed, ±10 knots, bank, ±5°; and rolls out on the entry heading, ±10°.
    $\begingroup$ The more precise standards was the main point that I was going to highlight as well! $\endgroup$
    – Lnafziger
    Jan 15, 2014 at 18:55
