When an aircraft carries a load, it could be mounted on top:
This is the Myasishchev M-4 carrying the Energia rocket fuel tank.
This is the American side.
Other times it could be mounted below:
My questions is:
What determines the reason where to mount the payload?
Attempt to answer:
The initial thought is, it might be easier to mount a large payload on an aircraft on top, which does not have a purpose built ground clearance. There simply may not be enough space under the aircraft.
Another reason (a concern for the FA/18) is that the ordnance mounted on the hard points generally will have gravity applying a tensile force on them, and when the aircraft is accelerating against gravity, the total force will increase on the mount point.
A top mounted load, in contrast, will lead to a compressive force in this situation.
Tensile force often might lead to a failure of the hard points faster than a compressive force. All ordnance have a maximum allowed G-limit. (Aircraft accelerating in any other direction where gravity is normal to it will not have to worry about gravity summing up to change the total compressive/tensile force.)
What I am left wondering is, are there other (aerodynamics or control/stability related) reasons, why a load may be mounted on top or to the bottom of the aircraft? How does the answer change for low, slow flying UAV?
I saw this post on reddit, and it talks about bringing the prop plane closer to the horizontal plane where COG is for quadcopters. What are the general principles?
Please also point me to books or resources.
