In this answer, it says:
Normally, increasing speed reduces the impact of viscosity (expressed as the Reynolds number). Viscosity is the reason why airflow detaches, and less of it means that flow will stay attached to slightly higher angles of attack.
I'm a bit confused as to why the Reynolds number changing (increasing, I think) would increase the critical angle of attack (cAoA) of the wing. From what I've heard, the Reynolds number just represents the ratio of inertial to viscous forces, determining whether the flow will be turbulent or not.
Why would simply changing the Reynolds number affect the stall AoA?
One thing I just realized while writing this is that it could be due to the turbulence from the higher Reynolds number helping the flow stay attached (which would make sense to me). However, the way the quoted text above is written makes me think it's due to something else.
One of the links in that answer also led to this answer, in which it states:
The lift curve slope increases a bit with Reynolds number
This is also puzzling to me, but it might require a separate question.
