All currently flying large propeller airplanes use turboprops, which are essentially jets driving turbines driving a propeller. So, seeing a propeller and hearing a jet is completely normal. (Basically, the thrust of the jet engine is not used to propel the aircraft directly, rather, it is used to drive a turbine. That turbine, in turn, drives the propeller.)
There are no six-engine turboprops currently flying, and the last six-engine large airplane was the Antonov An-225 Mriya with its six turbofans, which was unfortunately destroyed during the early days of the Russian invasion into Ukraine.
The drop tanks on the Lockheed C-130 Hercules look very similar to the engine nacelles from certain angles, and are almost evenly spaced between them, which can make them look very much like two extra engines from certain angles:
An RAAF C-130J Hercules military transport aircraft installed with external fuel tanks. Credit: © Royal Australian Air Force.
So, I would guess it is possible that you saw a C-130.
