If you take a short one hour flight in an A320, the flight will usually climb to around 25 - 30,000ft and then descend into its destination. The actual cruise at 30,000 will often only be a matter of minutes. The reason for this, I understand is it's the most economic (fuel sparing) flight path.
What is the most economical vertical flight path to take when flying a small plane (say a 152 or ultralight) for a flight duration of around an hour?
I recently tried the "A320" approach by climbing to 10,000ft (the flight ceiling) and then switching to idle. But since small planes often don't have a great glide ratio, including the one I used (C42), I believe that flight was less economical than usual, it took a very long time to get up there at a fairly high power setting.
