A normal subsonic enough, but still compressible flow will compress when it gets to the planes nose. But in supersonic flow, there won’t be this compression. There will just be a shockwave which turns the flow instead of the high pressure turning the flow. Granted, this depends on nose angle and the speed of the plane.
The shockwave itself has different properties, but those should be fairly even throughout the whole shockwave.
But if you look at the very tip of the nose in this picture, you will see a bigger black area, AKA different density.
Why is there this little area of more black/different density? The shockwave should be constant density, right?
Originally, I thought maybe this is because the angle of the nose was too high for an oblique shock to form, so a normal shock formed instead, but the nose seems to be at a fairly low angle so I don’t think this is the case.
