Here it explains how the bound vortex will change the lift distribution of a wing. What is meant by the lift distribution changing is that there is less lift at the tip, meaning the pressure differential between the 2 surfaces is less towards the tip. I think I understand this part.
However, I do not understand how this will make the tip stall first. If the pressure is higher (higher compared to the wing root upper surface pressure) on the upper surface toward the tip, I always thought that would make a stall happen easier.
For example, a lower pressure on the upper surface would cause the pressure recovery to not be handled as well, encouraging stall.
So to summarize, the bound vortex through some things explained in the linked answer will change the pressure distribution on the wing. It does this in a way where the pressure differential is less and less as you move towards the tip. Why would this pressure distribution promote stall?
  • $\begingroup$ This answer will help. $\endgroup$
    – sophit
    Commented Jun 13 at 18:14
  • $\begingroup$ Are some of the usages here of stall an abbreviation for tip stall, or are they really "stall"? $\endgroup$ Commented Jun 13 at 20:00
The lift distribution is given by:
$$l(\eta)=c_l(\eta)\,c(\eta)\,q$$
Where $\eta$ is the spanwise coordinate.
The notation $l(\eta)$ is meant to emphasize that the local lift $l$ is a function of $\eta$ -- i.e. it varies with $\eta$. Likewise, $c_l(\eta)$ and $c(\eta)$ are meant to emphasize that the local 2D lift coefficient $c_l$ and the local chord $c$ both can vary with span.
Often, we will divide by the dynamic pressure.
$$\frac{l(\eta)}{q}=c_l(\eta)\,c(\eta)$$
Aerodynamicists will use the quantity $c_l(\eta)\,c(\eta)$ as a scaled version of the lift distribution. Sometimes, they divide by a reference chord $\bar{c}$
$$\frac{l(\eta)}{q\,\bar{c}}=\frac{c_l(\eta)\,c(\eta)}{\bar{c}}$$
This still gives us a curve with the shape of the local lift distribution, but divided by two constants such that it is scaled to be similar to aircraft lift coefficients.
The important part here is that a non-uniform lift distribution $l(\eta)$ (which is all of them) means that the local lift coefficient $c_l(\eta)$ and or the local chord $c(\eta)$ also have a non-uniform distribution.
In fact, if the lift is large at the tips, that means that the local lift coefficient and/or the chord must be large at the tips.
Or, if the wing tapers (chord gets small at the tips), then even a uniform lift distribution will cause the lift coefficient to increase at the tips. We can see this by one more algebraic manipulation.
$$\frac{l(\eta)}{q\,c(\eta)}=c_l(\eta)$$
Here we see that the local lift coefficient depends on the ratio of the local lift and the local chord.
OK, what does all this mean?
Here is a swept wing (30 deg at the LE) with some taper ($\lambda$=0.5):
Here is the resulting lift distribution: enter image description here
The lift distribution (cl*c/cref) is in yellow, and the lift coefficient (cl) is in red.
The local lift coefficient represents how 'hard' that part of the wing is working. Let's assume that this particular airfoil is expected to stall at $c_l$=1.0. That is a 2D number -- and clearly this is a 3D flow. However, we can use the sectional lift coefficient compared to the 2D stall lift coefficient for the airfoil as a simple measure of how close to stall you are.
We see that this wing (at this angle of attack) reaches a peak sectional lift coefficient of about 0.887 at a span location of Y=2.8.
In terms of your question, the peak sectional lift coefficient is relatively outboard -- which means the wing will likely stall at that section (near the tip) first.
Here is the same chart for an un-swept wing (zero degrees at c/4).
Notice how the location of the peak lift coefficient moved inboard? Also notice how the lift coefficient distribution is much flatter?
Here is the un-swept wing, with the taper eliminated. Consequently, the yellow and red curves are identical.:
For an un-swept and un-tapered (and un-twisted) wing, the peak of the lift distribution is at the center line. This will stall from the center out, producing almost no rolling moment from the stall.
And, for completeness, here is the swept, but constant chord wing, again the red and yellow curves are identical.
As you can see, sweeping the wing changes the lift distribution and moves the peak of the lift coefficient outboard.
Swept wings are usually combined with tapered wings, which further pushes the peak of the lift coefficient outboard.
These things can result in wings with poor tip stall behavior.
Edit: Include image of line vortex influence.
When we talk about potential flow, we talk about how certain flow structures (sources, sinks, vortices, doublets, freestream) cause a velocity field around them. We combine many such flow structures to assemble a complex flow.
In the math abstraction, we say that the vortex causes a velocity field around it. However, when we talk about a wingtip vortex, we don't really believe the causality works the same way. The flow results in the wingtip vortex, not the other way around. I know this is confusing.
Here is an image depicting what a line vortex does. A vortex of a given strength causes a velocity field around it. Notice that a vortex has no influence on itself.
So, the trailing vortices cause a velocity increment at other places on the wing. So their influence is felt someplace else -- not at the location of the vortex.
  • $\begingroup$ I see, thanks a lot for your detailed answer. So as for a swept constant-chord wing, why will the maximum lift be made not at the center of the wing, or at location -2 / 2 in the last graph? If the chord is constant, why is this the case? (Not considering spanwise flow, unless that is the reason) $\endgroup$
    – Wyatt
    Commented Jun 13 at 23:46
  • $\begingroup$ Recall your question that spawned this one. Sweeping the wing moves the horseshoe vortices aft and changes the lift distribution. The center of the wing is least affected by the trailing vortices. $\endgroup$ Commented Jun 14 at 5:27
  • $\begingroup$ Right, but in the last graph, the horseshoe vortices seem to be affecting -2 / 2 most, not the center where the horseshoe vortices should have the most effect, correct? My theory is that this is due to spanwise flow. $\endgroup$
    – Wyatt
    Commented Jun 14 at 18:54
  • $\begingroup$ it would seem that the trailing vortices are causing an upwash near +-2 that causes the local alpha to be higher and therefore higher local lift. These vortices have less effect near the center line. $\endgroup$ Commented Jun 14 at 19:02
    $\begingroup$ I just posted an edit and image that might help. $\endgroup$ Commented Jun 14 at 20:22
