Usually I can solve CDMVT problems, but sometimes I feel I'm missing something important. For example:
  • I'm able to solve:
    Given WCA -012, TH 125, MC 139, DEV 002E. What are TC, MH and CH?
    T     V    M    D      C
    125 + 2 = 127 - 002E = 125
    ————————W(+)——E(-)———————————->
    TH=TC+/-WCA
    MH=TH+/-VAR
    MH=MC+/-WCA
    CH=MH+/-DEV
    125=TC-012 => TC = 137
    MH=139-102 => MH = 127
    CH =125
  • Using the same method, I cannot solve:
    Given: TC 183, WCA +011, MH 198, CH 200
    T     V      M     D     C
    194 + 4  =  198 + 002  = 200
    ————-W(+) —-E(-)——————->
    • TH is easy 183+011=194
    • Variation looks like +4 so 4W, and deviation looks like +002.
      But the correct results are variation is 004E (so minus 4) and DEV is -002 not plus.
Please someone clear me up what I am missing I feel like is important and I miss something critical.
Abbreviations used:
  • TN/MN: True/Magnetic North
  • VAR: Magnetic variation, positive when MN comes after TN, clockwise, said otherwise when VAR is east.
  • TC/MC: True/Magnetic Course. The track actually flown
  • TH/MH: True/Magnetic Heading. The aircraft heading.
  • WCA: Wind correction angle, angle added to desired course to get the heading to be flown.
  • CH: Compass reading
  • DEV: Compass error (deviation). Quantity added to compass reading to get the actual magnetic heading.
Thus we get:
  • MH/MC = TH/TC + VAR
  • MH = CH + DEV
  • TH/MH = TC/MC + WCA
given: MC = 139, TH = 125, DEV = 2, WCA = -12 (given are between brackets)
          C  +  D --> M  -  V --> T
Course              [139]   2    137
WCA                             [-12]
Heading  125   [2]   127    2   [125]
Answer: TC = 137, MH = 127, CH = 125
Because:
  • TC = TH - WCA = 125 - (-12) = 137
  • VAR = MC - TC = 139 - 137 = 2 (meaning MN is east of TN)
  • MH = TH + VAR = 125 + 2 = 127
  • CH = MH - DEV = 127 - 2 = 125
What are TH, VAR and DEV
given: TC = 183, WCA = 11, MH = 198, CH = 200
          T  +  V --> M  -  D --> C
Course               187    4   [183]
+ WCA                            [11]
Heading [200]  -2   [198]   4    194
Answer: TH = 194, VAR = 4 (east), DEV = -2
Because:
  • MC = MH - WCA = 198 - 11 = 187
  • VAR = MC - TC = 187 - 183 = 4 (so MN is east of TN)
  • TH = MH - VAR = 198 - 4 = 194
  • DEV = MH - CH = 198 - 200 = -2
I used the standard definition of the magnetic variation, positive when MN is eastward. You seem to prefer positive when MN is westward, just invert MH/MC = TH/TC + VAR, that is use: TH/TC = MH/MC + VAR and you'll get the same result.
