It's been (well) established that a shockwave can only be at the angle of the Mach cone. (I now understand this part). However, in this picture:
you can see that the shock is at 2 angles. I also understand why this happens. Mainly because of the 3D relieving effect, and also because the shock can never be at a greater angle than the Mach cone.
The question:
Why is the shock allowed to essentially have 2 angles in this case? Towards the rear and further away from the object, the shock is at a different angle than it is near the object. I understand why this happens, but I don't understand why a single continuous shock is allowed to have 2 different angles. Essentially, because the shock can only ever be at the same angle as the Mach cone, why is it seen at 2 different angles in this picture, considering the Mach cone is only at one angle in this picture?
Another example:
Here is a picture of a T-38C:
If you look closely, near the plane some of the shockwaves are at different angles than the others. When they get further out, they all tend to the same angle (the Mach cone). Why are the shockwaves allowed to have different angles close to the body? Why aren't they forced to the Mach cone angle, like the shocks are further out?
