This is taken from section 21 of Chapter 3, Compressors that discusses axial flow compressors in turbine jet engines.
The more the pressure ratio of a compressor is increased the more difficult it becomes to ensure that it will operate efficiently over the full speed range. This is because the requirement for the ratio of inlet area to exit area, at the high speed case, results in an inlet area that becomes progressively too large relative to the exit area as the compressor speed and hence pressure ratio is reduced. The axial velocity of the inlet air in the front stages thus becomes low relative to the blade speed, this changes the incidence of the air onto the blades and a condition is reached where the flow separates and the compressor flow breaks down
I'm trying to draw a connection to something I already understand, is this similar to the phenomenon that limits propellers to low speed? In order to produce positive thrust they need to spin faster and faster?
