Inspired by this question, why do shocks move further back on a wing as the Mach number increases?
Normal shocks on the surfaces of wings form when the air molecules of the pressure recovery area on the wing don’t have time to react to the incoming air. Not having time to react causes a rapid compression of the air, making a shockwave.
Now if the air on the wing was traveling faster, when it got to the pressure recovery, it would just collapse into a stronger shock but in the same position, right? Why does it not do that and instead move further back in the wing?
Some pictures to see what I’m taking about :
This is when the shock is half down the wing. (Ignore the separation part of the photo)
enter image description here Then at a higher speed, the shocks for some reason move backwards instead of just staying where they were and getting stronger. Why is that?
  • $\begingroup$ @sophit good point. Separation will still cause drag, but not wave drag in this case. $\endgroup$
    – Wyatt
    Commented Apr 21 at 20:53
  • $\begingroup$ The boundary layer separation aft of the shock wave does not cause wave drag as suggested in the first picture. Wave drag is an intrinsic drag generated at supersonic speeds and has nothing to do with boundary layer. As already suggested by @RobMcDonald beware of random pictures from the internet. Btw, what's the source of that picture? $\endgroup$
    – sophit
Why would it stay in the same place? Is there some physical object to keep it there? Something like a ridge or a bump or a throat of a nozzle?
On a smooth surface, the location a shock 'chooses' is determined by a balance of effects. One of those is the upstream Mach number -- as the airfoil goes faster, the supersonic region around the airfoil gets larger and the Mach number in it gets larger. Another is the back pressure.
Without worrying about the details, when we're faced with a balance of factors like this, there is no reason to think they will be the same as you vary the important conditions. In fact, it makes a lot more sense for them to be different.
Edit
Adding an image to illustrate the behavior the OP was asking about
  • $\begingroup$ I see, but I assumed the back pressure stays the same as the Mach number increases. Is this true? If so, it seems like it’d collapse in the same place? $\endgroup$
    – Wyatt
    Commented Apr 21 at 20:10
  • $\begingroup$ It would make sense if the back pressure decreased as you speed up, then the shock would travel backwards. Not sure why it would decrease or change though. $\endgroup$
    – Wyatt
    Commented Apr 21 at 20:35
  • $\begingroup$ It doesn't actually matter if the back pressure stays the same or not. When the Mach number is higher, the normal shock will be stronger. A stronger shock means a larger pressure jump at the shock. Check out the normal shock tables. en.wikipedia.org/wiki/Normal_shock_tables $\endgroup$ Commented Apr 22 at 4:36
  • $\begingroup$ Ah I see. So would that mean basically that the higher Mach number would make a stronger shock, and because of the stronger shock, it would ‘push’ the shock backwards? $\endgroup$
    – Wyatt
    Commented Apr 22 at 4:43
  • $\begingroup$ Basically because of the higher pressure shock, the shock pushes itself back. (Higher pressure pushes things) Is that correct? $\endgroup$
    – Wyatt
    Commented Apr 22 at 23:18
