I've noticed some pilots preselect their destination QNH on their side of the FCU. In order to preselect the QNH, you need to momentarily switch out of STD which made me wonder:
Assuming your side is switched on for altitude reporting (on the ATC/TCAS panel):
- Will ATC receive a different altitude while the pilot is preselecting their QNH?
- Does TCAS use this barometric altitude during interrogations? So could this trigger a TCAS if the QNH difference to STD is drastic enough?
I know that it usually on takes a few seconds to do, but could be longer if the QNH difference is big enough or if the pilot is distracted.
