I have done aerodynamic analysis on a UAV. Is it possible to calculate pitch rate and yaw rate of my UAV depending on design parameters? (I have aerodynamic analysis of the wing, CL, CD, MAC, W, etc.)
  • $\begingroup$ What do you mean with "aerodynamic analysis"? Experimental or analytical? $\endgroup$
    – sophit
    Apr 10 at 12:04
  • $\begingroup$ steady state CFD $\endgroup$
    – A K
    Apr 10 at 12:42
  • $\begingroup$ Well, then you just have to run two (or more, according to your resources) simulations with say two different aspect ratios and then compare the two results (in terms of pitch/roll rate) $\endgroup$
    – sophit
    Apr 10 at 14:25
You need to do a static maneuverability analysis. This involves knowing the size of the control surfaces, calculating their effectiveness (which is not easy), some knowledge of the moments of inertia of the aircraft, etc.
In general, this is covered in textbooks on Stability and Control, alternatively, flight dynamics, or flight mechanics. Roskam has a two-volume set, Etkin & Reid is another -- there are many to choose from.
