EDIT: I now understand relative wind is parallel to the travel of the glider. Ignorance was the basis of my earlier confusion.
I looked at some toy and commercial gliders and all of their wings were mounted with a 0 or a positive angle of incidence. This means that when a glider is gliding down, say at a glide angle of 5 degrees, wouldn't the angle of attack be -5 degrees? And wouldn't the negative AoA make the glider fall from the sky rapidly because of all of the down force? Or does the relative wind change?
I am making a small glider using the airfoil A18. I am confused because the glider doesn't seem to have any data below an AoA of 2. I am further confused because an angle of attack of 2 degrees has the highest Cl/Cd ratio which I thought usually happened at an AoA of 6-7. Furthermore, the Reynolds number is the highest which means that the wing creates turbulence which again I thought happened at a high AoA.
My glider will have a computer with an AHRS system that can control the elevator with a PID system so it can aim at one specific pitch, and I believe that pitch would be the glide angle. But to find the glide angle, I would need to know the lift and drag force which comes from the lift and drag coefficients. I don't have a wind tunnel so I can't calculate the lift coefficient at a different AoA. Plus, I'm launching at a high altitude (80,000 feet) so the lift force will change throughout the flight. Please tell me if I'm missing anything!
I also desperately need help on reading the graphs on AirfoilTools.com. Which graph is most important? Which polar should I read?
Why do these two different polars have different Reynolds number, with the same angle of attack? Is the Reynolds number something you input instead?
Am I overthinking this? Should there just be one angle, based on guess-timating, that my flight computer pitches down at, like -10 degrees? Or how would I gaurentee a stable AoA thoughtout my whole flight (probably 2 hours)?
Again, I am trying to make a sub-249 gram glider that is dropped, not thrown, from a high altitude. I welcome any tips.
Please excuse my ignorance and sorry for so many questions!
