I would like to determine the amount of fuel required for a flight at a given range/payload combination - ideally from the payload/range-diagram [1] of the corresponding aircraft alone.
I know that for the case of maximum payload, the fuel required for a flight at a given range can be read off the extended payload-range diagram as (cf. [2], Section 3.3):
$$m_{fuel}=m_1-m_2$$
where $m_2=MZFW$ and $m_1$ can be computed as $m_2=((m_1-m_2)/R(A))*R$
Image source: Figure 3.4 in [1]
But how can I read the fuel for an arbitrary payload that is smaller than the maximum payload (which is described in the diagram by the line up to point $A$)?
[1] Aircraft Fuel Consumption – Estimation and Visualization
[2] Aircraft Payload‐Range Analysis for Financiers
