How much of the drag produced by a typical GA/airliner/cargo plane's wing at cruise is induced, frictional, and pressure drag?
  • $\begingroup$ Induced drag is mainly due to pressure drag. It'd be more correct to ask how much is induced and how much is parasite $\endgroup$
    – sophit
    Commented Feb 18 at 15:45
At best L/D, an aircraft (with a simple parabolic polar) has half induced and half parasite drag.
If half the parasite drag is from the fuselage -- and you are flying at best L/D, then we can say that of the total drag:
25% fuselage parasite 25% wing parasite 50% induced
Or, of just the wing
33% parasite 66% induced
You likely aren't cruising exactly at best L/D. And you will have other components that contribute to the parasite drag of the aircraft. But this should give you a reasonable idea of how to make a starting estimate.
