19
I purchased a wooden box of glass and nitrate negatives at a flea market in Berlin Germany in 1995. There are about a dozen more in the lot with planes in them.
This image has never been published to my knowledge.
Any ideas on the plane or the pilot?
Black and white photo of man standing in front of a biplane
    $\begingroup$ This image seems to be reversed left-to-right. $\endgroup$ Feb 7 at 8:12
    $\begingroup$ Yes it is, I had to choose between the emulsion side and the other - not knowing which is correct. $\endgroup$ Feb 7 at 15:55
    $\begingroup$ You can see it's reversed because of the cut of his coat: the left side always comes over the right for men. $\endgroup$
    – Party Ark
    Feb 8 at 17:50
29
About the airplane: It looks like a Fokker D.II.
About the engine: it definitely looks like a Oberursel_U.I.
About the pilot: thanks to @PortreeKid we know him to be the test pilot Werner Emil. We speculate that he doesn't look happy since he is missing a button on his jacket 😄
    $\begingroup$ The missing button is the reason for his unhappiness :) $\endgroup$
    – U_flow
    Feb 7 at 11:14
  • 14
    $\begingroup$ fokker-history.com/en-gb/d-ii#&gid=1175965900&pid=17 Emil Werner also seems to be unhappy about a missing button. $\endgroup$ Feb 7 at 13:28
    $\begingroup$ @sophit yes but faaaaar better quality. Presumably same series and this one is a close up $\endgroup$ Feb 7 at 14:06
    $\begingroup$ It seems to be Emil Werner, not Werner Emil, right? (The problem being that both "Werner" and "Emil" are German first names, but of course either one could be the family name here. The answer has it the other way around than the link.) $\endgroup$ Feb 7 at 17:45
    $\begingroup$ @PortreeKid it seems to me that this is not the same series, but literally the same photo. If you overlay them in an image editor, they are identical to the last crease on the uniform, and the face doesn't move the tiniest bit. Negatives may be duplicated (and maybe flipped in process?), so it's likely that the OP got a copy. $\endgroup$
    – IMil
    Feb 8 at 0:00
