Chapter 5, section 3 of the AIM says that victor airways are "designated from 1200 ft above the surface (*or in some instances higher) up to but not including 18,000 ft MSL."
What are the instances of victor airways having a floor higher than 1200 ft AGL? Is it just when class G airspace extends higher than 1200 ft AGL?
Thank you
Victor airway’s bottoms are higher than 1,200ft when there is class G airspace that prevents the class E from existing there.
  • $\begingroup$ Is there a missing "only" in this sentence, or are you merely confirming the information in the question? $\endgroup$ Feb 4 at 10:22
  • $\begingroup$ I was more directly answering the question. There may be other situations but I am not knowledgeable on that. $\endgroup$
    – Taylor B
    Feb 4 at 16:34
