EGT is available but not the temp of the exhaust nozzle in the CFM56 series.
  • $\begingroup$ EGT is T49.5. Which engineering station are you looking for? T8? T9? Which CFM56 model? $\endgroup$
    – mins
    Commented Nov 30, 2023 at 20:05
  • $\begingroup$ @mins Are you adhering to the AS755 standard (Aircraft Propulsion System Performance Station Designation and Nomenclature)? Please do, we have created these standards to communicate clearly about positions in the gas path (although sometimes even OEMs don't). Note that 3 digit (or 4) station numbering is now common, 49.5 is located in the turbomachinery according to the standard numbering (while it should have been 0495), the EGT starts after the last turbine exit (mechanical expansion process) which is station 050. $\endgroup$
    – 0scar
    Commented Dec 4, 2023 at 7:58
  • $\begingroup$ @Setare how far downstream are you looking at? $\endgroup$
    – 0scar
    Commented Dec 4, 2023 at 8:21
  • $\begingroup$ Turbofan engines CFM56 series. $\endgroup$
    – Setare
    Commented Dec 4, 2023 at 11:06
  • $\begingroup$ My question is the Temperature downstream of the LPT and exhaust Temp from the nozzle $\endgroup$
    – Setare
    Commented Dec 4, 2023 at 11:08
The total temperature, denoted as Tt, remains constant throughout the nozzle as it performs no thermodynamic work. In the context of station numbering, the entry point of the nozzle is labeled as station 5 (or 050 according the AS755 Aircraft Propulsion System Performance Station Designation and Nomenclature standard), while its exit point is designated as station 8 (or better 080). Consequently, the ratio of the total temperature at station 080 (Tt080) to that at station 050 (Tt050) is equal to 1.0.
$$\frac{Tt_{080}}{Tt_{050}} = 1$$
