A Class D airspace ceiling is typically depicted with a two digit number surrounded by four brackets depicted below.
Why do some Class D airspaces have the same four brackets, with four additional lines within those bracket lines. I've checked the chart user guide and it shows an example of it but that example isn't consistent with airports across the US. Picture below.
As you can see, where it says [32], there are only four right angles around it, whereas in the second example, where it says [62] there are four additional lines in between each right angle and I can't find an answer anywhere.
