26
Please help identify this aircraft. Photo taken in Rijeka, Croatia early 1900s
55
This is a Dornier Do D, a floatplane torpedo bomber variant of the Dornier Komet, which was built for the Yugoslav Royal Navy. It's considerably bigger than it looks in your picture!
203 served with the Yugoslavian 20th Hydrosquadron from 1927, originally based in Kumbor, Montenegro. In this early variant, the pilot sat in the forward cockpit, right under the wing - you can just see him in the second picture - a bold design feature. Later variants rearranged the fuselage and cockpit. Here is the exact same plane -
Dornier Do D source Dornier Do D source
Dornier Do D source
  • 15
    $\begingroup$ Outstanding answer! $\endgroup$
    – Jamiec
    Nov 15 at 15:41
    $\begingroup$ Wow. Thank you for the information. That is way more than I was expecting. -Chris $\endgroup$ Nov 16 at 2:44
  • 7
    $\begingroup$ @ChrisVolker That is way more than I was expecting - so show your delight by accepting the question 🙂 (checkmark under the votes at the left of the answer, turns green when checked) $\endgroup$
    – WoJ
    Nov 17 at 12:40
