I know that by designing an airplane or a car close to a teardrop, we can reduce the drag. My question has to do with the surface friction treatment. Some torpedoes glide in water more efficiently when wrapped in bubble cloaks.
Some feathers have textures to reduce friction. Some modern bathing suits textures help reduce friction.
Are there studies on surface treatments, such as texture, special paint, grooves, or perforations, to reduce drag?
edit
Implied in my question is: If there are any results that do reduce skin friction, where have they been applied?
    $\begingroup$ Literally thousands $\endgroup$
    – sophit
    Nov 15 at 5:38
    $\begingroup$ @sophit I think the question -- asked as "are there studies on this?" truly can be answered with what you have here and the slightest bit of elaboration. Like a sentence or two on a couple of the studies and a link to each, followed by the link you posted supporting the statement "... and thousands more like these." The question is asking, has this been studied, and you provide conclusive proof that yes, in fact it sure has. $\endgroup$
    – Ralph J
    Nov 15 at 20:59
  • $\begingroup$ @RalphJ: Sorry I don't get your comment. Are you suggesting me to write a proper answer or not? 😄 $\endgroup$
    – sophit
    Nov 16 at 6:57
    $\begingroup$ This seems to be so broad that the only possible answer to the question is "Yes". $\endgroup$
    – FreeMan
    Nov 17 at 16:24
    $\begingroup$ Well, since nobody else is going to answer this... Y'all are welcome. ;) $\endgroup$ Nov 18 at 17:31
Yes, there are literally thousands of studies on the subject. A keyword search on this link brings up many examples. (credit to Sophit)
There's also a similar question on this site that may be useful. (credit to Peter Kampf)
And there are surface material studies for other purposes that you might also find interesting. (credit to Steve Pemberton)
