So I was wondering how exactly the startup vortex forms, why it dissipates, and where it's located in relation to the trailing edge of the wing. Also, why does a startup vortex form when circulation around the wing changes? (see quote below)
"This starting vortex formation occurs not only when a wing is first set into motion, but also when the circulation around the wing is subsequently changed for any reason whatever." Millikan, Clark B., Aerodynamics of the Airplane
If someone could explain that to me, I'd appreciate it, thanks
(If someone could also explain how the tip vortices contribute to the startup vortex, I’d also appreciate it)
(What I meant by startup vortex ^)
  • $\begingroup$ It's written just a couple of line before in the same book. I'd also suggest you to use something more modern 😉 $\endgroup$
    – sophit
    Nov 14 at 7:06
  • $\begingroup$ Maybe this answer or this one help? $\endgroup$
    – sophit
    Nov 14 at 19:21
  • $\begingroup$ @sophit thanks, those answers did help a bit, but I'm still kind of stuck on why exactly the vortices stop being formed when at higher speeds, and why changing circulation will make startup vortices. I read the lines in the textbook you provided but I am still a bit confused. $\endgroup$
    – Wyatt
    Nov 14 at 21:16
  • $\begingroup$ It's just a matter of Newton's second and third law (aka momentum conservation). If the circulation around the airfoil changes (in time or space) then a proportional and opposite circulation is released in the wake. $\endgroup$
    – sophit
    Nov 15 at 5:42
  • $\begingroup$ @sophit Ah okay, so what direction and where will the startup vortex formed from changing circulation be? $\endgroup$
    – Wyatt
    Nov 15 at 21:38
