In this answer, it claims that the reason for lift decreasing at the wingtips is due to airflow around the wingtips. If I'm thinking correctly, that is due to the air below the wing spilling on to the top, decreasing lift (correct me if I'm wrong). That made me wonder if adding winglets evens out the pressure distribution along the wing, because less air spilling over (from bottom of wingtip to top) would increase lift, right? In that case, say you went to an extreme, and made a massive winglet, would that basically get rid of tip vortices and make the pressure distribution almost completely even?
    $\begingroup$ A closed wing would be even better. $\endgroup$
    – sophit
    Nov 1 at 22:25
    $\begingroup$ @sophit Closed wings have vortices still, correct? Would there still be air leaking from the bottom of the wing to the top in that case? $\endgroup$
    – Wyatt
    Nov 1 at 22:44
  • $\begingroup$ Does this answer your question? Is a winglet better than an equal span extension? $\endgroup$
    – sophit
    Nov 2 at 8:21
Winglets do change the lift distribution on a wing.
To really take your line of thought to an extreme, replace the winglets with flat walls that extend up, down, forward and aft to infinity.
If you place a rectangular wing in a wind tunnel such that the span is equal to the width of the wind tunnel, you can simulate two-dimensional flow with a uniform lift distribution across the wing.
Most high quality airfoil data has been taken in a tunnel set up to use this effect.
Of course, winglets also add weight and wetted area (skin friction drag). So you don't want to install a giant winglet on an aircraft.
  • $\begingroup$ ah, yeah that's what I was thinking. I was a bit confused because I just assumed there was another factor that also causes it. Thanks for your help! $\endgroup$
    – Wyatt
    Nov 2 at 1:06
Whitcombe originally called winglets "tip sails", because they operate much like sails on a boat. They exploit the energy in the tip circulation by placing an airfoil surface such that lift is generated inboard. Since the circulation flow is moving inboard, it has a positive angle of attack to the winglet and the lift force is perpendicular to that angle of attack. The lift force is pushing the winglet toward the fuselage, but also angled forward somewhat. The forward component of the lift force is, literally, thrust as far as the airplane is concerned. Winglets make thrust, like a sail boat close hauled.
While making that thrust they are consuming the energy in the circulation and creating an outwash (downwash sideways) that opposes the circulation, weakening the core of the vortice and having an effect similar to a span increase.
The end result is the lift distribution is improved similar to a span increase, and some thrust benefit is also extracted from the flow that may exceed the winglet's drag.
They only generate enough energy to compensate for their own drag when the wing is "working hard" operating at higher AOAs, that is, low indicated airspeeds. The only airplanes that cruise at low indicated airspeeds are jets that fly above 30000 ft (for example, 443kt TAS at 37000ft is only 250 kt indicated). This is generally why you only see winglets on jets, and putting them on straight wing low altitude aircraft is mostly for looks, or to improve rate of climb (where AOA is relatively high enough to get useful work out of them).
    $\begingroup$ besides being only beneficial at high AoA, a winglet also helps to stay in a lower wingspan class. Only then is it really justified. $\endgroup$ Nov 2 at 8:27
    $\begingroup$ I'd always assumed the funny turned up tips on the Canadair CL-415 were some kind of winglet intended to improve its climb performance. An aerodynamicist chum who had some involvement with the program told me they were actually a bandaid to restore dihedral effect that was lost due to the tall, flat fin-like PW120 nacelles, that replaced the round R2800 nacelles, making a high wing configuration into effectively a quasi mid wing configuration, in a plane with no geometric dihedral. $\endgroup$
    Nov 2 at 12:31
    $\begingroup$ Same thing with the turned-down wingtips of the He-162. They were a band-aid for too much dihedral and since the design had to be ready for service soon, there was no time to change the jigs to a smaller dihedral. They were called "Lippisch-Ohren" (Lippisch ears) after the person who used them first on his tailless designs. $\endgroup$ Nov 2 at 12:50
  • $\begingroup$ I've read that after the kinks were worked out with that, and increasing vertical stab size IIRC, they were actually very nice handling aircraft. $\endgroup$
    Nov 2 at 15:01
    $\begingroup$ I don't think the tip tanks are at fault. After all, the maximum sideslip angle should be less than 15 degrees. But since low wing airplanes need more dihedral, those 5° are still too low. $\endgroup$ Nov 3 at 10:34
