Is it possible for an aircraft propeller to become supersonic? I am not referring as for the aircraft, only the rotating blade. I know it is extremely unlikely for a propeller plane to go supersonic, but could the propeller ?
    $\begingroup$ Possible on what level? In theory you just have to spin it fast enough. Most aircraft designers in the middle 1900's knew that it was a bad idea, and tried to create designs that would avoid it. $\endgroup$
    – MikeB
    Oct 31 at 12:50
5 Answers 5
Two examples I can think of immediately: the F-84H "Thundescreech" and the Soviet/Russian "Bear" bomber. The former aircraft failed to enter service, in part because it was literally so loud as to make people working on the apron physically ill. The Bear has been in service for decades, however.
Both of these aircraft had propellers that ran supersonic at the tips -- the Bear has eight of them, though they're less strident than those of the Thunderscreech (probably because slower at the tips).
  • $\begingroup$ I think another reason is that the Bear's props tend to do it mostly at cruise altitude where air density is less and thus sound propagation isn't as bad. I've heard reports however of pilots of intercepting NATO aircraft feeling unwell from the effect. $\endgroup$
    – jwenting
    Nov 1 at 9:24
  • $\begingroup$ I seem to recall reading that the US SOSUS system (passive underwater sonar for detecting submarines) could detect Bear BOMBERS flying near them) $\endgroup$
    – DJohnM
    Nov 1 at 18:32
  • $\begingroup$ @DJohnM I think you're correct. $\endgroup$
    – Zeiss Ikon
    Nov 1 at 19:17
Yes the blade tips can go supersonic at redline rpm if the blades are long enough, the tip speed simply being a function of those two variables, along with the right temperature, which determines the speed of sound.
Some common airplanes have propellers that produce supersonic shock waves on takeoff, generally long two bladed ones. They produce a distinctive, very loud BLAAAAAT sort of sound as they pass by you on take off. Slowing the propeller RPM just a little makes the sound go away. The speed of sound being temperature dependent, the effect is worse when the air is cooler than warmer.
It's common on airplanes with radials and two blade propellers like the DeHavilland Beaver. The Harvard/T6 trainer, with an R-1340 radial had a particularly intense "sonic blat" that is familiar if you've ever watched one at an airshow.
Cessna 180s/185s with two blade propellers also do it at takeoff RPM. A 185 taking off from a lake on a cool morning will have that distinctive searing sound that echoes off the local hills.
If a lake or other location is unusually noise sensitive, it's a common practice to back off on the RPM a little bit as soon as airborne, about 100 RPM or so, to make the "sonic blat" go away.
On of the benefits of switching to a 3 blade prop is lower takeoff noise, because the shorter blade tips stay subsonic.
The tips of propeller blades can go supersonic, however this is very inefficient so in practice this is rarely done. One notable exception is the Russian Tu-95 turboprop bomber which cruises at 380 knots (440 mph, 710 km/h). The propeller tips of the Tu-95 move at supersonic speeds, which makes the plane extremely noisy.
Tu-95 Tu-95 (photo: RAF, via: Wikimedia Commons, OGL v1.0)
Yes, you can figure that out yourself with simple math. The circumference of a circle is 2 Pi r, and let's say the speed of sound is 343 meters / second -- it depends on a few parameters, but 343 m / s is what the wikipedia page uses. My plane's engine redlines the rpm at 2700 rpm, that is 2700 revolutions per minute. You can now solve for r and thus determine the prop length at which the tip goes supersonic at 2700 rpm. We have:
2 Pi r 2700/60 == 343
and you get a value for r of 1.21311 meters.
You can play with the rpm, but 2700 is a typical redline for a piston plane's engine. Of course, our props aren't 1.21 meters in radius, but this equation should give you an idea on the radius / rpm relationship.
  • $\begingroup$ The rpm of the engine might not be the same of the propeller if there's a gearbox between them, as often is the case. $\endgroup$
    – sophit
    Nov 4 at 13:56
  • $\begingroup$ Good answer although from the question point of view probably you would start with a known tip radius and redline rpm, then calculate the speed to determine if the tip goes supersonic. Then you can also determine if is goes transonic which I think is avoided also. Although both speeds are affected by the propeller shape, which can cause a shockwave to occur prior to the tip reaching actual supersonic speed, but that's a nuance that probably only the airplane manufacturer would get into because of the complexity. $\endgroup$ Nov 4 at 14:40
  • $\begingroup$ @sophit, good minor point, I should have talked about the prop rpm, not the engine rpm. $\endgroup$ Nov 6 at 2:20
  • $\begingroup$ @StevePemberton, disagree on the first part of your comment, given the question I intentionally wanted to have the radius the (only) variable to solve for. That way it's also not a question if it goes supersonic, but at which radius it goes supersonic. Your point about trans-sonic and prop shape determining a shockwave is well taken, you're right about that. $\endgroup$ Nov 6 at 2:25
Yes. A former supervisor was an antiaircraft missile supervisor. He reported that TU-95 bombers were easy to spot because of the distinct signature of the supersonic speed of the propeller tips.
    $\begingroup$ Welcome to Aviation. You'll note that this aircraft was already mentioned in 2 other answers. Have anything else to add? Please take the tour to see how things work a bit differently here than at other discussion boards. $\endgroup$
    – FreeMan
    Nov 3 at 17:27
  • $\begingroup$ Also potentially missing here is if the signature was sound (per John K) or on some form of Radar using doppler to ID contacts which would seem more likely for an antiaircraft missile supervisor to be observing.. $\endgroup$ Nov 4 at 9:30
