11
Not a pilot, but I've been a passenger before and I'm writing a sci-fi book trying to use realistic aviation terms (so ignore my use of slang and acronyms here). I understand that V1 is when you have to keep going and there isn't enough room on the runway (realistically speaking) to reject the takeoff without suffering a runway excursion.
However, it would also seem that under those same grounds, there are rare cases in which the PIC may have to abort because the aircraft literally cannot take off (i.e. stuck control surface = plane can't take off at all). In these exceedingly rare cases where the only possible option is to stop - even if doing so would overrun the runway, here are my questions:
  1. How brief would the "window of opportunity" be to reject takeoff at V1 be? That is, would the non-PIC calling out "V1" and less than half a second later the PIC orders an abort (due to being unable to take off) make a difference as compared to a rejected takeoff five or ten seconds post-V1? It would seem to me that the chances of actually pulling off a successful rejection and not overrunning the runway would increase with less time elapsed after the V1 callout.
  2. Besides the control surface problem, are there any other circumstances you envision where the aircraft cannot take off that mean you have no choice but to reject takeoff after V1? (And, on a more morbid note, if there was a runway incursion involving a person at V1, my book has the ship hit them and take off regardless, so I wonder if that's the case for the plane too - if something happens at V1, you have to fly the plane, regardless of what's in the way). Or to be more precise: what are the grounds, in your opinion, that justify rejecting takeoff at V1?
  3. Even assuming the rejection was successful enough that either the aircraft doesn't overrun the runway or the aircraft does overrun the runway but no one dies, what kind of consequences can the PIC/non-PIC expect?
    $\begingroup$ Related: What if you have a double-engine failure after V1 but before VR? $\endgroup$
    – Bianfable
    Oct 2 at 6:03
    $\begingroup$ @AndreasRejbrand: V1 is calculated assuming thrust reversers are inoperable. $\endgroup$
    – Joshua
    Oct 2 at 17:36
    $\begingroup$ Could you re-phrase that, please? Surely in every case, it's necessary to reject a takeoff if the aircraft is incapable of taking off? Isn't that half the purpose of V1? $\endgroup$ Oct 2 at 22:08
  • $\begingroup$ @RobbieGoodwin V1 is meaningful for a case in which the pilot might go flying but also might try to stop. If your dry runway V1 is capped at rotation speed, you're probably capable of continuing the takeoff even if an engine fails somewhat before V1... because if the runway were icy & slick, your lesser ability to stop might mean you'd commit to flying sooner than VR. So in some range of speeds (dry rwy), you could do either; V1 is where you commit to go fly. Also, while single engine aircraft can have a "max refusal speed", they have no V1. There, 1 engine out = "incapable of flight"! $\endgroup$
    – Ralph J
    Oct 3 at 14:24
  • $\begingroup$ Uh… really, Ralph? I thought everyone knew V1 was when you could and V2 when you must take off. $\endgroup$ Oct 3 at 20:16
23
If the aircraft is truly incapable of taking off -- the locked controls case, let's say -- then the only choice involved is along the lines of, go off the end of the runway really really fast (you kept accelerating once past takeoff speed), or go off the end of the runway not so fast, with max braking, max reverse, full spoilers, etc. So if both engines just failed, it matters not how fast you are in relation to V1, you'd better start stopping, because you can't go flying -- at least, not for very long, and that certainly wouldn't end well either!
In the world of high-performance jets, the V1 speed is the speed at which you have determined you will commit to taking off. That's it. Before that speed, if I get a serious problem, I'll stop; above that speed, even with a serious problem (typically, along the lines of a fire or an engine failure), I'll continue the takeoff and deal with the problem in the air. And the performance data supports continuing the takeoff from that point even with one engine out.
So the statement -- which you'll see many, many places -- that "above V1 you can't abort & stop on the runway" isn't always accurate. If I have a powerful & light aircraft that needs 3,000' of runway to accelerate to takeoff speed, and another 3,000' to come to a stop if an abort is initiated at takeoff speed, and I'm taking off from a 12,000' long runway, then the speed that I'll use for the "V1" callout will be my takeoff (i.e. "rotation") speed, VR. But, could I successfully abort from a speed faster than that in this case? Absolutely.
Consider the case when my jet has a light load of passengers + fuel, and the identical aircraft taking off behind me has a heavy load. His VR speed, when he rotates up and starts to go flying, will be higher than mine because he has a heavier aircraft. So maybe he needs 4,000' to accelerate to his takeoff speed, and 4,500' feet to stop from that speed. So his VR is above mine, and his V1 matches his VR, so his V1 is higher than mine... well, if he can stop on the runway having initiated an abort at the higher speed, in my lighter aircraft I certainly could also initiate an abort at that higher speed and stop successfully.
We cap our V1 speed at VR, because it doesn't make sense, in a planning & performance standpoint, to consider rejecting the takeoff after you've started to rotate & go fly. But at any time up until that V1 speed, you aren't committed to flying yet... you can still abort.
As for timing, how quickly the Pilot Flying would have to initiate the abort after event (let's say the "bang" of an engine seizing -- a really violent engine failure), that's defined by the manufacturer and incorporated into the performance data. They test how long, in given conditions, it takes from the time the pilot starts the abort procedure, until the aircraft is stopped.
Then they build in assumptions (which they state in the performance data) about reaction time and so on. So if the test pilots, knowing what's coming, reach XXX knots & shut down an engine, they'll delay some time (perhaps 1 second) to say "Abort!", reflecting that everybody besides the test pilots has to process what just happened & will take a non-zero timespan to determine than an engine failure occurred.
Then, having stated "abort," they may delay one more second, and initiate the abort procedure -- perhaps one engine in idle (simulating, failed), one engine in reverse, full braking on the wheels, full spoilers. And when the aircraft stops, that distance is the data point.
Then they repeat that test at enough different conditions (gross weight, temperature, etc) so that they can confidently draw up performance charts so that I can tell, on "this" day with "these" conditions that I have, what is my accelerate-stop distance and speed -- what will it take for me to go from stopped, to takeoff speed, to stopped again, using all the given assumptions? If my VR speed is higher than this speed, then my V1 will be below my VR (and at, or perhaps slightly below, this accelerate-stop speed determined from the charts & the available runway). Or, if I can accelerate to a speed higher than my takeoff speed & still stop within the available runway, then my V1 probably matches my VR.
So to your (a) question above, yes, the odds of "successfully" aborting above V1 depend greatly on how far above V1 the pilot initiates the abort. If it's a half-second beyond, maybe the jet stops in the overrun, with no or minor damage, while 5 seconds beyond, the jet is through the overrun, the approach lights, the boundary fence, and into the highway just outside the airport. Or, maybe this was the day you only needed 6,000' to accelerate & stop again but you had 12,000', so despite the late abort everything turned out okay. Or maybe the runway has EMAS, and that ended up protecting the approach lights, fence, and highway.
As for your question (b), this is where people get creative, and sometimes a little bit aircraft-specific. A total electrical failure on the runway, at night with an overcast you'd be climbing into might be such a scenario. In the T-38, there was a specific combination of generator failure with an additional electrical failure that left you with a pretty ugly set of instrument outages, and it was a discussion topic of, do you take the jet into IMC in this condition, or do you abort late & trust the barrier to stop you. Maybe a massive armada of aircraft suddenly appearing at 200' with the certainty that going flying means a midair with one or more of them would qualify (like I said, getting creative here).
But for the most part, the aircraft designers have put lots of work into designing out as many of those sorts of scenarios as possible, so that you can safely go flying when an engine fails at or above V1.
For question (c), in an airline or military world at least, there would be an investigation into everything that happened, and did the PIC make an appropriate decision at the time, knowing what he knew and given the guidance that he had. If he aborted many seconds beyond V1 because he got a warning light on the cabin pressurization panel, the investigation will probably determine that he screwed up pretty seriously. Or, if he put the airplane into the EMAS rather than taking the total electrical failure airborne on the dark & stormy night, they could conclude that he made a really good decision.
Depending on how punitive the employer is and how badly he messed up, the pilot might be fired, or might get some (punitive) time off & some retraining, or there might simply be a debrief and some "lessons learned" for everyone, and he keeps on flying. In the case of a sufficiently egregious screw-up and an NTSB investigation, the FAA might pull his license so he's done flying altogether.
    $\begingroup$ How about the OP's proposed scenario, of control surfaces not working for some reason? Like, you pass V1, get to VR, pull on the stick, but the nose doesn't come up (at all, or not enough). You could keep gaining speed to see if that helps, but if it doesn't, you've made things much worse. So I'd guess if you knew you had enough runway to slow most of the way down, and something safe-ish to go off into, you'd abort at the cost of some damage to the gear and the lawn and maybe lights and/or ILS antennas $\endgroup$ Oct 2 at 6:13
  • 11
    $\begingroup$ @PeterCordes That actually happened before: Texas MD-87 Crash Update: Jammed Elevators!. The MD-80 has tab-controlled elevators, so you cannot easily check these pre-flight. $\endgroup$
    – Bianfable
    Oct 2 at 6:33
  • 7
    $\begingroup$ I read a case awhile back of a pilot discovering on lifting the nose wheel off the runway (between V1 and VR) he discovered rudder control left something to be desired. So he threw his training out the window so to speak, commanded elevators full down and maximum brakes, and overran into the runway lights. Investigation found hydraulic line rupture; that plane was unflyable so it's a good thing he aborted the takeoff. $\endgroup$
    – Joshua
    Oct 2 at 17:43
    $\begingroup$ Interflug 102 is another example, with the pilot flying realizing after V1 that the elevators were locked. It didn't end well, partly because the flight engineer immediately shut down all four engines, preventing the use of reverse thrust. $\endgroup$
    – cavok
    Oct 3 at 1:20
    $\begingroup$ Think of V1 as a "bad things will likely happen if you're going faster than this when you abort" speed. While not mentioned in other comments, this may often be a function of braking ability. The usefulness of remaining runway will be greatly diminished if the brakes melt, but if that's going to happen, every extra knot of speed one gains before aborting takeoff will increase by more than a knot the speed with which one will leave the runway. Since kinetic energy is proportional to the square of speed, and badness tends to scale with kinetic energy, every bit of speed reduction helps. $\endgroup$
    – supercat
    Oct 3 at 17:00
