Airport SID/STAR/Approach Primary Records in ARINC 424 contains two fields with altitudes: columns 85-89 and columns 90-94. How to interpret if both fields are empty ? What are the altitude constraints in this case?
Thanks in advance!
Sign up to join this communityAirport SID/STAR/Approach Primary Records in ARINC 424 contains two fields with altitudes: columns 85-89 and columns 90-94. How to interpret if both fields are empty ? What are the altitude constraints in this case?
Thanks in advance!
