When flying an open-cockpit plane (specifically a Tiger Moth):
By Towpilot (Own work) [GFDL (http://www.gnu.org/copyleft/fdl.html) or CC-BY-SA-3.0 (http://creativecommons.org/licenses/by-sa/3.0/)], via Wikimedia Commons
Where helmets are worn, what precautions or certifications need to be observed to mount a small video camera (such as a GoPro) thereto, if it's even possible? Obviously it would be very bad if the camera were to come undone in flight, and there might be an effect on the helmet's impact protection, so my guess would be that it's simply not allowed, but perhaps it can be done if certain conditions are met.
  • $\begingroup$ I guess the guy sitting behind you might have objections too, considering he'll be the first stop, should it come undone... ;) $\endgroup$
    – falstro
    Dec 7, 2014 at 16:41
  • $\begingroup$ Traditionally the student sits in the rear seat, which makes the empennage the first stop. I don't think that's any better on an aircraft made of wood and fabric. I'm assuming that you'd ask the instructor's permission as well as that of the airplane's owner or flying club, in any case. $\endgroup$
    – Dan Hulme
    Dec 7, 2014 at 16:55
    $\begingroup$ Really? I always thought that the student was traditionally in the front seat? Hence the cut shirt tail $\endgroup$
    – falstro
    Dec 7, 2014 at 16:57
  • $\begingroup$ Well, Michael Schumacher has probably a word to say about the safety of such mounts. $\endgroup$
    – Antzi
    Aug 28, 2017 at 9:33
It's certainly possible to use a GoPro in a Tiger Moth: there are plenty of videos online to prove it. That means the question is, is it legal and if so how to do it safely?
Legally, there isn't anything relevant that I could find on the UK's CAA site (your profile says you're in the UK), but in any case most discussions on cameras in GA aircraft have been about attaching a camera to the aircraft, not to the pilot (see this question, for example). For obvious reasons, it's difficult for any aviation authority to regulate what pilots wear or carry on their person and if there are no specific regulations that means that only the general don't do anything stupid or dangerous rule would apply. I assume that the UK has something equivalent to 14 CFR 91.13 in the US:
No person may operate an aircraft in a careless or reckless manner so as to endanger the life or property of another.
(Note: I'm ignoring any contractual issues here, like what your insurance company or FBO allows.)
From a safety point of view, the main risk of a portable camera is that it comes loose and ends up blocking a control surface externally (e.g. wedging in the rudder or elevators) or a control internally (e.g. falling to the floor and getting stuck behind a rudder pedal).
One specific concern with a helmet-mounted camera is that if it does fall off then it's very close to your face and it could obstruct your vision or even just startle you, which would probably be bad news on short final with a gusting crosswind. (Pilot distraction from operating the camera controls is another potential issue but that's true of any gadget.)
Ultimately I would say it comes down to how confident you are that the camera is secure and not going to get in your way: if you are, then go for it. I don't think the attachment issues are significantly different from skiing, parachuting, driving sports cars etc. with a helmet camera, and that happens all the time. And cameras are a great tool for reviewing and improving your performance (especially if you have full audio too), which makes the 'risk' very worthwhile, in my opinion.
