11
Taken from a bus window on a highway leaving Taipei going west and south, these photos show what I assume is a commercial jet on roughly northeast(?) approach to Taipei's Songshan Airport July 24, 2023 at 16:45 UTC+08 (local time).
Twin engines at the rear just in front of the tail, and sort-of-delta-ish-wings rather than skinny ones, but maybe it's just very long inner flaps compared to what I'm used to seeing? If so, maybe a short description of why the wings + flaps seem to look different than what a long time passenger might think flaps normally look like would be helpful.
Photos taken by cell phone through a tinted bus window pointing very high (almost straight up) by the third and closest one.
what's this plane?
what's this plane? what's this plane? what's this plane? click for full size
20
It could be a Bombardier Global 7500 by a quick search. I can't find any good pictures from under but they look kinda similar, and depending on the livery of the plane you saw, could've operated in Taiwan as a private jet
G700 blueprints
    $\begingroup$ Wing shape a better match IMO than an MD-80 in the other answer. Also the winglets, almost visible in the source image. $\endgroup$
    – Jamiec
    Jul 31 at 14:38
    $\begingroup$ This was just a quick search, I'm not a civilian aviation kind of guy. That's why I used an F/A-18 on my profile picture rather than, say, a 777 $\endgroup$
    – Mateo
    Jul 31 at 14:42
  • $\begingroup$ The pointy nose is also a better match. This could very well be it. $\endgroup$
    – Bianfable
    Jul 31 at 14:42
    $\begingroup$ The gear placement is very similar too, although I couldn't find an image for the underside $\endgroup$
    – Mateo
    Jul 31 at 14:45
    $\begingroup$ looks very much like it. swept back winglets are kind of noticeable on OP's picture $\endgroup$
    – jkztd
    Jul 31 at 15:05
16
It was a Bombardier Global 7500 (all credits should go to Mateo, he was the first to identify the aircraft type correctly). This aircraft, registration 9H-VID was operating for VistaJet, flight VJT750 from Tokyo (HND) to Taipei (TSA).
Photo of the aircraft source: Jetphotos, copyright atc1110
A screenshot from the Flight Radar 24 replay, showing the flight ID is below:
Flight radar 24 screenshot showing the aircraft over Taipei
