There are several airfields nearby where parachuting activities routinely take place. How far away is considered to be a safe distance from the airfield when flying past it en-route to another destination? Are there any particular frequencies to monitor besides the airfield frequency? How would I know parachuting is happening besides any NOTAMs?
Qualification: I worked at a busy drop zone for 10 years. Just announce yourself on the airfield frequency about 5-10 minutes out and they'll tell you what's going on, including which runway is active and how high they are jumping from - standard altitudes are 3000ft and 12,000ft AGL. At our place it was really simple: left-hand for 34, right-hand for 16. We landed everyone on the east side, and if we are dropping at 3000 all day you can just pop up to 4000 and be completely out of the way. Under no circumstances make a cross-field pass as that's usually right in the middle of everyone else's landing pattern, and we don't carry radios. If you are just passing by a 2km buffer is lots - no one is likely to be in the air that far away. No reply usually means nothing in the air. |
First of all, recurring DZ's have parachute symbols on sectional charts, so look for them! The FAA regulations have this to say:
This means that if you expect chute activity in the area, ask ATC!
And as always, check the NOTAMS! |
Here in Seattle, jump aircraft are usually talking with ATC (Seattle Approach). The jump airplane will announce 5 minutes out and the when the jump occurs. |
In Europe, it's generally a good idea to be on the Flight Information Service (FIS) frequency, where you can receive information about active drop zones and/traffic information to the airplane performing the drop, as they need to call in on the FIS frequency and announce when they start the drop. |
I'm not a pilot. I did attempt to get a parachute license, but stopped after a couple of jumps. I jumped at two different drop zones. (And I'm from Sweden) I just thought I'd offer a view from the other side. At the DZs where I jumped, the pilot always talked to ATC before takeoff, so I would assume that ATC will know of any parachute activity. The parachutists will fall, so if you can stay above the plane that will drop them, you'll be fine. Where I jumped, 4000 m was highest allowed altitude without oxygen, so no one jumped from higher than that. The parachutists will want to land at or very close to their field. During the freefall part, they don't really drift with the wind. Chutes will typically be opened at about 1000 m, and from that altitude, they will drift significantly with the wind. Thus, they will be dropped upwind, and will typically not move very far downwind of the field, especially not at high altitudes. So, in order of simplest/safest:
This should perhaps be taken with a few grains of salt, but hopefully others can chime in if I've said something incredibly stupid. :) |
