Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Most pictures of airliner's nose sections show small dark tube- or fin-shaped instruments sticking out of the fuselage below the cockpit windows.
For example this Airbus A350 shows them well: A350 nose section Source: Airliners.net
Other airliners (737, A380, 787) carry similar instruments at the front.
I'm sure Google would be able to tell me if only I knew how to correctly phrase my question, but...
These instruments sticking out of the fuselage, what purpose do they serve?
share|improve this question
I am not sure other planes have these. All of them have the instruments on the sides. But I don't remember seeing the ones in the centre anywhere else. – Jan Hudec Aug 18 '14 at 15:26
Now seeing the answer, indeed, every aircraft has a pitot tube (here mounted on the AoA vane to improve precision at high AoA), most have AoA vane and the faster ones have total air temperature probe (needed to derive Mach number), but sideslip vanes are not common. Most planes rely on a level or lateral axis of accelerometer in IRS for coordinating turns. – Jan Hudec Aug 20 '14 at 8:06
Why is there a hatch above the (FO's?) seat? Emergency escape? – CGCampbell Aug 20 '14 at 13:00
@CGCampbell Yes, the A350 is the first Airbus with an escape hatch in the roof. – florisla Aug 20 '14 at 13:35
up vote 29 down vote accepted
Here's a better picture showing all probes, and labeled:
A350
Link to original, high-resolution, unnumbered picture
They are:
  1. Ice detector
  2. Multi-function probe 1
  3. Static port
  4. TAT probe
  5. Side-slip vane
  6. Pitot probe
  7. Angle-of-attack vane
Airbus.com has a PDF (page 69) PDF (page 84) about the various probes.
As the name suggests, the multi-function probes record different types of data. Here are more details:
The piloting of any aircraft involves knowing the relative speed of the aircraft with respect to the airflow surrounding it, that is to say to the relative wind. This speed is determined with the aid of sensors of the static pressure Ps, of the total pressure Pt and of the angle of incidence “alpha”. “Alpha” provides the direction of the speed vector in a reference system tied to the aircraft and Pt-Ps provides the modulus of this vector. The three aerodynamic parameters therefore make it is possible to determine the speed vector of an airplane.
These are covered by a US Patent.
Someone asked a similar question here.
share|improve this answer
#5 is a upgraded yaw string, invented by the Wright Brothers, and used on their 1902 glider. upload.wikimedia.org/wikipedia/commons/5/50/… – rbp Dec 26 '14 at 22:40
Your link to the PDF seems dead. – Manu H Oct 7 '15 at 14:56
@ManuH That was rally odd. I didn't expect Airbus to do that. Anyways, I found another document with that information. – Farhan Oct 7 '15 at 17:36
discard
