Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have limited experience with flight simulators but I have never bumped into a plane with manual transmission while, on the contrary, it's very common for other means of transportation (like cars and bikes) that rely on engine with some form of transmission control.
First of all, I'd like to know if it's actually true that no airplane have (or had) manual transmission and, secondly, why that is so.
share|improve this question
Incidentally, most trains and some other vehicles have no gearbox either, for other reasons, so the question, might be turned around (Why do cars and bikes have one?) Wikipedia has a rather readable article on the topic. – Relaxed Aug 11 '14 at 16:25
I always wished that my plane had an R (rallye) gear... – PlasmaHH Aug 11 '14 at 19:10
I read a story a long while ago told by Douglass Bader about crashing his Hurricane on take off because he had it in high gear, so it had a manual shift. – PatFromCanada Aug 14 '14 at 13:25
@PatFromCanada:You mis-understood. Planes of that era had two speed superchargers, that could be shifted from low boost to high boost, with low being used at lower altitudes and high being required for maximum performance at altitude. This is not the same as shifting the propeller RPM. – Skip Miller Aug 14 '14 at 20:03
@PlasmaHH R usually indicates reverse in gear boxes. Now THAT would be interesting in an aircraft... – jwenting Aug 15 '14 at 6:45
up vote 41 down vote accepted
Aircraft have fixed gears (when they have gears at all)! However in a sense a variable-pitch propeller can be considered analogous to transmission in a car and it was manual in some aircraft.
The power transmitted by propeller is, within some reasonable range, proportional to its rotation rate. And so is, again within some reasonable range, the power produced by the engine. So for slow planes a fixed pitch propeller with connected by fixed gear does a decent job. As you open the throttle, the engine speed increases, so does the propeller and that's exactly what it needs to do to transmit the power. Simpler aircraft have no gears at all and propeller is mounted directly on the engine shaft, higher power engines often have 2:1 reduction gear as the engine rpm would be too high for a propeller.
Now at higher speed, the apparent propeller pitch is reduced as the air is already moving, so it would spin faster and faster and eventually too fast for the engine. To counter this, faster propeller-driven aircraft have variable pitch propeller. As speed increases, it is set to higher angle of attack (coarser) so it keeps delivering power without increasing rpm.
Early variable pitch propellers had manually controlled pitch, but quite quickly constant speed propellers were developed (many WWII aircraft had them already) where a weight-on-spring controls the propeller pitch so that constant rpm is maintained. The manually controlled units required a lot of attention and the constant-speed system is rather simple, so manual pitch control was quickly abandoned.
And that is kind of equivalent to perfect variable gear transmission. The pilot still has a throttle lever and a propeller pitch lever and selects power and rpm independently. Higher rpm allow higher power, but don't require it, so landing is usually done with low power, but max rpm so the engine reacts quickly if power is added (does not need to spin up). During cruise some more moderate value is selected (according to manufacturer recommendation) to reduce wear of the engine.
Turboprop engines always have constant-speed propellers, because in a turbine engine the difference between turbine speed at idle and at full power is not actually that big. Again the rpm limits maximum power, so landing is done with low power, but high rpm and the engine reacts quickly when power is added.
Last the turbojet/turbofan engines just turn the turbines and compressors as they need. It's not much different from the fixed propeller really, though the jet engines now usually have variable guide vanes in the stator (that are just linked to rpm).
share|improve this answer
Because most aircraft engines do not have geared transmission at all:
enter image description here Image from wiki
The power is directly transmitted from the turbine to the compressor with a rigid shaft.
It is true, though, that some engines have it, in particular, propeller engines:
Image from ATSB
but you have to realize that this a fixed gear ratio, no gear shifting is involved and thus, no manual nor automatic "transmission" is required.
What you might have, in "old style" propeller engines, is different levers/knobs for manifold pressure/throttle, propeller pitch and mixture.
32
Apart from aircraft, boats also use fixed gears. The thing to realize is that changing gear ratios is only really necessary for vehicles that use wheels to stop the engine from stalling when you first start to move because turning the wheels means needing to shift tons of weight. In contrast, turning a propeller, be it in air or water, only requires you to overcome the friction of the drive shaft and the tiny amount of initial air/water friction. If you jack up a car and have the wheels not touch the ground I bet you can spin the wheels directly in 5th gear without going through gears 1-4 – slebetman Aug 11 '14 at 7:39
Do turbine engines also have gears? I can't imagine that the compressor and fan operate at the same speed; do they or is there some other mechanism in play? – Nick T Aug 11 '14 at 15:51
@NickT jet engines do not have gears, turbine and compressor share the same shaft. What you can have are multiple shafts: 1 for high pressure copressor/turbines, and 1 for low pressure turbine/fan. Some even have 3. – Federico Aug 11 '14 at 16:30
@slebetman - It is the clutch not the gearbox that is required to start off. With many trains this is done using electric motors as part of the transmission as they can supply torque without any rotational speed, while the diesel engine provides electrical power for the motors. Equivalent to the gearbox would be propeller pitch, changing the amount of thrust for an amount of throttle and revs. – Kickstart Aug 12 '14 at 8:07
@Kickstart: Ah, but even the clutch can't start a car directly in 5th gear. The problem is that the gear ratio necessary to defeat the huge amount of inertia is very different from the gear ratio you want to cruise at – slebetman Aug 12 '14 at 8:10
Torque
I suspect that the real answer involves torque.
Engine RPM with vehicle stationary
Aircraft engines don't have or need multiple gears because the engine doesn't move the aircraft from standstill by applying torque to wheels. Instead an aircraft engine can run at full RPM while the aircraft is stationary at the start of a runway.
If you put your car in top gear (6th?), ran it at maximum RPM (8000?) and dropped the clutch, something would break - at the very least you'd burn the clutch and crawl away slowly. Aircraft engines don't have or need a clutch, ultimately because they are pushing air, not turning wheels on tarmac.
With only the top gear on a moving car, it would still be impossible to drive on a steep road. The gear box is not only needed to overcome the car inertia, but more generally to use the engine in a compatible torque region, from large torque / small displacement (low gear), to large displacement / low torque (high gear). This is the same principle at work in a block and tackle. Please correct me if I'm wrong, which may be very possible. – mins Sep 7 '15 at 12:16
@mins: You are not wrong and that is the point I had in mind when writing my answer. Even with a fixed pitch propellor, an aircraft engine operates in its effective torque region without the need for multiple selectable gear ratios. – RedGrittyBrick Sep 7 '15 at 12:37
Variable ratio gearing in road vehicles (cars, bicycles, etc.) is required to match the speed and torque capabilities of the prime mover (gas engine, human leg power, etc.) to the speed and torque requirements of the road wheels over varying conditions of vehicle speed, road grade, etc. Basically, there is a need (or at least benefit) to vary the mechanical advantage between prime mover and driving wheel(s).
The prime mover (jet or piston engine, turbofan or propeller) in an aircraft produces thrust largely independent of airspeed, so for many aircraft, variable ratio gearing is not required. For propeller aircraft, it can be beneficial to vary the mechanical advantage between the powerplant and the airstream. It is done, not by variable ratio gearing, but by varying the pitch of the propeller. For one thing, varying the pitch can vary mechanical advantage over a continuous range where a gearbox is limited to a few fixed steps. For another, gearing systems add a lot of weight. Changing gears would mean disconnecting the engine from the propeller as a different gear ratio is selected - that's a big reliability/safety issue, and for a piston engine, couldn't even be workable. Piston engines can't run without a flywheel; in an aircraft, the propeller serves as the flywheel.
So, where the benefits of variable mechanical advantage justify the added cost, weight, and complexity, a variable pitch propeller is fitted.
Some variable pitch systems provide a lever which directly control the pitch - the pilot moves the lever over a range between "fine" (engine gets more mechanical advantage, suitable for take-off) and "coarse" (engine has less mechanical advantage, suitable for cruise).
Other variable pitch systems provide a lever which selects a target engine RPM. The pitch control system continously adjusts the propeller pitch in an attempt to maintain the selected RPM. The pilot uses the throttle to increase or decrease engine thrust, and the pitch control to optimize the engine RPM for the operating conditions (take off, climb, cruise, etc.). On a PA32-300, for example, the pitch control would be fully forward (max RPM) for taxi, take-off, and initial climb-out, but would be adjusted back somewhat for cruise to reduce engine RPM (and fuel consumption).
You could think of the pitch control systems I've described as analogous to a manual and an automatic transmission respectively, but the analogy is a loose one at best.
Slightly different answer to the last one. Air whipping engines don't need a lot of torque to push through viscous friction that resists blade travel. That is why quadrotors work and yet are very light.
Simple comparison, push against a wall and there is a normal force pushing back. Now wave your arm in the air. The only resisting force is a function of your arm speed. It's tiny.
Since they don't need to use gear reduction to increase torque like other applications, they don't need a gear changing transmission. In fact Bernoulli effect works on thrust from air flow over the blade so you want the propellers spinning as many times as possible to get maximum lift. Electric motors for quadrotors spin 10000 RPM for example. They control motor spin speed through throttling air and fuel for turboprops or pulse width modulation for electric motors. Turbines are air and fuel I think as well, but that's not my expertise.
Flight simulators don't have geared transmissions because real planes don't have geared transmissions. The closest thing a plane would have is a variable pitch prop.
With a vehicle with wheels, the engine rpm is easily calculated as a ratio with ground speed and the gearing. There's nothing like that with an aircraft.
Agreed. A variable pitch prop is the airplane equivalent of a transmission. – Sponge Bob Aug 14 '14 at 13:19
A lot of complicated answers... but the simple truth lies in the term itself - transmission!
Power must be transmitted, somehow, from the engine to whatever will push the vehicle forward - the wheels or the propeller. Internal combustion engines have an optimum power transmission rpm range - above or below which the efficiency of the engine drops drastically.
The difference between land vehicles and air or sea vehicles is, as mentioned by others here, that the friction between the wheel & land needs a much greater starting torque to get that wheel moving. Whereas, rotating a propeller through the air or water can be done much more easily & quickly.
In fact, this also ties up with why only land vehicles have (and can have) brakes. Neither air nor sea vehicles can have brakes. Because braking involves that same friction which was overcome to get the vehicle started. Due to lower co-efficients of friction, both sea & air vehicles continue to move even if the engine stops functioning. Obviously, air vehicles never need to be braked to a standstill while still in air. But water vehicles do and that is achieved by reversing the direction of the propellor's rotation.
actually aircrafts can have airbrakes (spoilers) and most definitely have wheel brakes. plus, reverse thrust. Sure, these are not used while in flight, but they exist nevertheless. – Federico Aug 12 '14 at 13:11
@Federico: Actually, some aircraft are certified to use reverse thrust in flight. The DC-8 re-engined with turbofan engines is one, and there are others. – Skip Miller Aug 12 '14 at 13:25
@SkipMiller thanks, I didn't know. – Federico Aug 12 '14 at 13:29
Because propellers in water and air use the friction to move the object. And this friction is far less than the one between asphalt and tires. In one way, the gas is acting as gearbox. The other side of this coin is that it makes it hard to do fast accelerations from 0.
Another factor not mentioned is that in land vehicles gears are used for travelling slowly, so the engine can stay in its operating range. But an airplane won't fly below a certain minimum stall speed, so gears are pretty pointless. In a typical small plane, your range of flying speeds (say 65-150 mph) corresponds to an engine speed range of roughly 1700-2500 rpm. If you throttle back to idle (or your engine quits), you basically have to glide, trading altitude for the airspeed needed to stay above stall speed.
discard
